Hesitation @ 4-5k - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 19 (permalink) Old 08-18-2009, 12:48 AM Thread Starter
Hesitation @ 4-5k
Until the bike warms up. Once it warms up, it pretty much goes away. What do you think this could be? I have installed K&N's, ran a few tanks of Seafoam, and just recently installed 4 Iridium plugs. I checked the boot clamps and they were lose, but tightened them, and this didn't help. Maybe I should pull the tank off, and check the primary wire connections to the coils.
Slip is offline
post #2 of 19 (permalink) Old 08-18-2009, 01:29 AM
The Professor
lance328's Avatar
Most of our bikes do run like crap untill they reach opperating temp. Now there is a difference between pretty much goes away and goes away! Which it it? How old is your bike? How old are the plug wires? What battery do you have? What fuel do you run? Has the bike spent most of it' life inside or outside? How many miles?
The more info the better the diagnosis will be!!
Most likely the cause is a vacuum leak or the carb bowl vent is restricted.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #3 of 19 (permalink) Old 08-18-2009, 03:00 AM Thread Starter
It is a 96 with 20k miles on it. It usually goes completely away. While yesterday, I did noticed it stumbled briefly even after warmed. But no, it usually runs quite well after it warms up. The plug wires look old. Don't know what kind of battery I have. I will look later today. I run 87 octane. There is some surface rust on some of the fasteners, so it might have spent some time outside, but covered.
Slip is offline
post #4 of 19 (permalink) Old 08-18-2009, 04:22 AM
The Professor
lance328's Avatar
Have you checked to see if your carb vent tube has not bottomed out in the back of the right filter cover?
As said before they run better when at temp. You may have a crap Flooded Wet Cell Battery, Get a DEKA ETX15L MF AGM batterty ASAP!!!!!!!!!!!!!
Go to your Auto Parts store and get a tube of Dielectric grease, spend a day or weekend and put a little on every connection the bike has. Just a little dab on the female connector, and YES!!! every connector. You will have to remove the fuel tank, seat, headlight, side covers and neck covers.
AGAIN!!! Replace the battery with the one in the link below.!!!
Clean and or replace the air cleaners. replace left carb to petcock vacuum hose, replace rear carb vacuum hose if it is not capped.
Replace spark plug wires from link below.
WIRES
http://cgi.ebay.com/ebaymotors/Kawas...d=p3911.c0.m14
DEKA BATTERY
http://cgi.ebay.com/ebaymotors/Deka-...4506.m20.l1116
The one you wil get is 210CCA and not 190CCA as listed.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #5 of 19 (permalink) Old 08-18-2009, 12:03 PM
dirtrack650's Avatar
My guess is needle/air screw/idle jet adjustments.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #6 of 19 (permalink) Old 08-18-2009, 02:39 PM Thread Starter
DT
I think they are 3 turns out.
Slip is offline
post #7 of 19 (permalink) Old 08-18-2009, 02:40 PM Thread Starter
A
Thanks for the info. What do you mean by this?
Slip is offline
post #8 of 19 (permalink) Old 08-18-2009, 03:05 PM
flitecontrol's Avatar
If your carbs haven't been modified, there is a vent hose that goes to the right air filter box. From the factory, the hose is cut square and can get up against the filter housing and interfere with proper air flow. When you check it, cut it at a 45 degree angle and put it back. That way, it can't bottom out.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #9 of 19 (permalink) Old 08-18-2009, 03:11 PM Thread Starter
Just curious of the area of the housing where the hose goes into. I had the filter cover off to install the K&N, and I didn't see a vent hose.
Slip is offline
post #10 of 19 (permalink) Old 08-18-2009, 03:16 PM
Then its either slipped out or the carb has been modified. Not sure which is which, but the mod is called either marbleing or coastering. If its slipped out that can cause a lot of problems with the bike running well. One member (Krebsne?) ran his under the tank. It needs to be in a location where the wind can't get to it.
"Black Beauty"
Old Blue
