Help with jetting my lean vn750 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 13 (permalink) Old 08-10-2009, 09:21 AM Thread Starter
McGyver
Hammer034's Avatar
Hello Vulcan gurus,
I recently picked up an 86 Vulcan 750 (non California)
This bike is all stock.
It runs very lean,The plugs insulators are white.just like when removed from the box.. At any rpm besides idle the bike has some small backfiring while not under load. When riding it I cant here the backfiring but I can feel it surging and every once in awhile it sneezes.
It has 175 compression on each cylinder.
It doesnt seem to have the decel pop so im probably not gonna marble it.(yet)
I cleaned the carbs out and replaced a blown out enrichener diaphram.
It currently has 132 mains and 38 pilots.
I was thinking of trying some 135 mains and 40 pilots.
Im at 1089 feet elevation,
What do you guys think.
Will it possibly help.
Thanks
Hammer034 is offline
post #2 of 13 (permalink) Old 08-10-2009, 09:47 AM
fergy's Avatar
It sounds more like you may have a vacuum leak or too much air getting into the intakes. How are your air filters? Check for leaks around the carb boots and vacuum ports/hoses by shooting some carb cleaner B12 around various areas while the bike is idling and see if it surges or coughs.
I guess it could also be starving for fuel some, but I'd lean more to the air leak side, no pun intended.
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #3 of 13 (permalink) Old 08-10-2009, 12:24 PM Thread Starter
McGyver
Hammer034's Avatar
I have already checked for vacumn leaks with carb cleaner and a propane torch.
I had the carbs off and tore apart and cleaned them.
The boots appear in real good shape.
It was my father in laws bike who has recently passed away.
He was the original owner of the bike and told me before he passed that he never had the carbs off.
I drilled the tamper plugs and tried adjusting the screws out to 3 turns, it runs alot better but not perfect.
One of the air filters was old and falling apart,and bits of it got into the carbs bleeder holes the other one was new.
I wrapped the air filter cage with some air filter material used for our intake fans on our cnc"s at work,this fiber material is probably less restrictve than the original foam filters tho..
I know that some engines are tuned to run with air filters only and run lean without them.(new lawnmowers for example)
Im a pretty good mechanic and know alot about bikes and how carbs work.
The bike may have a vacum leak but i cant find it.
I have a new filter on order so i guess i will wait and see how it runs with that before I go any further.
Maybe i will even try plugging the air intake hole on my custom filter side just to see if it fattens it up a bit.
I may give it an earshave,new pipes and the such later on but just wanted it to run good stock for now.
Thanks for the reply tho.
post #4 of 13 (permalink) Old 08-10-2009, 12:36 PM
fergy's Avatar
You're answering a lot of the questions I thought of after posting. These bikes are set lean from the factory and it might be as simple as the one air filter being less restrictive. I've got a feeling that might be the whole problem.
It's a good plan to get it running great "before" doing the ear shave and mods. You'd be surprised how many decide to do stuff here while the bike is running bad. That's why I wouldn't change jets. It should run like a screaming ape when it's all working, stock. Good luck with it all, and it's good to have you in our group!
Fergy
2002 VN1500 Classic
SEAFOAM JUNKIE!
fergy is offline
post #5 of 13 (permalink) Old 08-10-2009, 12:43 PM
On His Lady Vulcan
wkrizan's Avatar
If your bike is completly stock and your 3 turns out, youre WAY to far out on your pilots for one. They come stock turned out at..... OH GAWD I am having a mind fart and can't for the life of me think what the stock setting is. More coffee please... Anyways my guess would be due to that air filter breaking apart on you has caused fuel blockage somewhere. Even though you cleaned them, clean them again, even the float needle. Tear it all apart. Good luck to you.
EDIT: Or as Fergy has stated....LOL
Peace
Pictures of the "Ladies"
wkrizan is offline
post #6 of 13 (permalink) Old 08-10-2009, 01:22 PM
Simple Solutions
seebeeare's Avatar
o dont think your stock bike has jet issues im not what do the plugs look like marbeling and blocking that vac line leading to the air diaphram under the seat should richen u up slightly the stock turn on the piolet screw is 1 5/8 what do your puggs look like ? how is spark u got good gaps and strong spark at each hole? i recomend iridium plugs pricy but highly recomended... so u are running lean when u ride with the choke on do u have the same hesitation??a lil seafoam in the tank and new plugs i bet you'll see the improvement...
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
How To Test the Stator
seebeeare is offline
post #7 of 13 (permalink) Old 08-10-2009, 02:04 PM Thread Starter
McGyver
Hammer034's Avatar
First all these forums are great.
And so are the people.
I wouldnt really think a stocker would have jet issues either.
Im gettin closer.
I went from 1.625 to 2 turns out on both mixture screws.
No more backfiring at steady throttle.
Still has i little niss tho,cant figure out if its both cylinders or not(damn goat)
One cylinder seems to stop firing at real low rpm.The carbs still have the factory balance mark on them.but im gonna balance them and see what happens.
Im gonaa also check the 2 coils resistence's and see if all is good.
I had it running in the dark and didnt see any spark leaks.
I did have one between the long spark plug cap and wall in the hole when i got the bike, Cleaned the caps out put in new plugs and all seems well.
Ive got a adjustable spark tester I might check spark in a bit but it seems fine at the plugs.
Its good now to where im the only one that notices the miss. but im kinda picky about how my toys run.
Carbs are surgically clean,so i dont think i wanna clean em again.
Thanx all
Ill keep ya posted.
post #8 of 13 (permalink) Old 08-10-2009, 03:20 PM
I don`t have any techie advice to add, just a welcome to the forum. Glad you are getting the problems Hammered out. Sorry, I just couldn`t resist the pun.
post #9 of 13 (permalink) Old 08-11-2009, 10:21 AM
dirtrack650's Avatar
My bet it's the air cleaner. CV carbs are sensitive to any changes in the air intake.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #10 of 13 (permalink) Old 08-11-2009, 10:29 AM
fergy's Avatar
I agree. Hopefully we will know soon when he gets the replacement air filter installed.
Fergy
2002 VN1500 Classic
SEAFOAM JUNKIE!
fergy is offline
