Ear shave- everything I need... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 37 (permalink) Old 07-30-2009, 01:41 AM Thread Starter
99vulcan750's Avatar
Well, I am taking the carbs out for a cleaning to find what's wrong and while I have them out I will do the ear shave. I want to make sure I have all the parts before I take them apart so I can get to riding faster...
(2) #140 main jets. http://www.z1enterprises.com/detail.aspx?ID=1928
(2) #40 idle/pilot jets: http://www.jazzmotorsports.com/pack-...n-p-48045.html
(4, 2 each needle) shims for needles: http://www.z1enterprises.com/detail.aspx?ID=1934
(2) emgo crank case air filters: http://www.z1enterprises.com/detail.aspx?ID=221
(2) KN filters #RC-2340 http://www.kensautowholesale.com/ser...ers-and/Detail
Does that about do it?
NOW FOR QUESTIONS:
---I am at 4500 feet elevation... should I go to 142 main jets? one 140 and 142?
---Do I need both the emgo and the KN filters? or just one or the other?
--- anything else I need to know? I am planning on removing the air box, the ears, and perhaps increasing performance and getting better acceleration and speed...
anything I am missing?
Also, does anyone have some of these parts and want to sell them?
I hope to do this fix next weekend...
'99 VN750 with 8900 miles and growing (3,111 when I bought it 03-22-08)
Ear shave with Unipods
Drilled mufflers and degoat
TOC springs
N/C Street shield EX windshield
Jumbo Saddleman Highway Studded saddlebags
Willie and Max Saddlebag mounting kit
License plate turn signals
Home made sissy bar
Luggage Rack from Scoop
http://youtube.com/user/99vulcan750
99vulcan750 is offline
post #2 of 37 (permalink) Old 07-30-2009, 02:35 AM
Simple Solutions
seebeeare's Avatar
float bowl gaskets just in case.... i reused mine without a problem but there isnt much u can do if u tear one.... u r removing the upper airbox ? get a vacume cap for the carb and 2 larger ones for the reed valves i chose this rout instead of coastering for cost reasons ....
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
How To Test the Stator
seebeeare is offline
post #3 of 37 (permalink) Old 07-30-2009, 03:05 AM
The Professor
lance328's Avatar
As seebeeare said get two bowl o-rings and two jet cover o-rings.
The K&N's are for the carbs and the emgo's are for crankcase ans fuel vent.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #4 of 37 (permalink) Old 07-30-2009, 03:09 AM Thread Starter
ok... thanks,,, I changed the O rings last summer... think they might still have to be replaced?
TOC springs
Home made sissy bar
post #5 of 37 (permalink) Old 07-30-2009, 03:23 AM
The Professor
lance328's Avatar
They should be fine.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #6 of 37 (permalink) Old 07-30-2009, 06:40 AM
Newb with a Bullet!
krebsne's Avatar
This brings up a good question- do you HAVE to coaster when you ear shave? I did just because it made sense to me. But can you ear shave and leave the reed assembly in place?
Otherwise, if you haven't costered (or at least marbled) you may need that stuff as well.
I got mine here-
http://cgi.ebay.com/ebaymotors/Kawas...Q5fAccessories
Current VN: 03 VN1600A
Past VNs: 92 VN750A, 98 VN1500A
Future VN: 94/97 VN1500A basketcase/bobber
krebsne is offline
post #7 of 37 (permalink) Old 07-30-2009, 07:00 AM
Simple Solutions
seebeeare's Avatar
I got mine here-
i didnt coaster when i shaved i just plugged the reed assembly with big vacume plugs aand a tiny zip tie...
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
post #8 of 37 (permalink) Old 07-30-2009, 03:40 PM
Send a message via AIM to Acid7711
Ohhhhhhh man! You're going to have a worllllld of fun! I know I sure have! Ha!
Acid7711 is offline
post #9 of 37 (permalink) Old 08-09-2009, 10:47 PM Thread Starter
ok, I am buying the idle jets... are they type 21 or type 22 keihin jets? or neither?
are these the right ones?
TOC springs
Home made sissy bar
post #10 of 37 (permalink) Old 08-09-2009, 11:02 PM
Newb with a Bullet!
krebsne's Avatar
Lance- If you've been following my "wit's end" post (sorry if you've written there, I can't recall) you know I'm battling some final tweaks of my earhsave which I had a buddy do for me.
I am about to go out there and move the vac line that comes off the T on the carbs. Right now it is attached to the right Emgo filter. The left is the crankcase breather.
So obviously when I move this line, I will have NOTHING plugged into that Emgo. What SHOULD be there?
Is that T line another name for "fuel vent" or am I missing something? What exactly is the "fuel vent"? One end attaches to the Emgo... where is the other?
Is this potentially part of my problem or if the T line is the fuel vent then is it just a case of sometimes you need the second Emgo and sometimes you don't? In which case it's just there for looks?
krebsne is offline
