Running Rich & bowl vent location - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 07-30-2009, 12:50 AM Thread Starter
Got a couple of questions on my 95 VN750:
Where does the vent line for the carb float bowls go? I had it routed to the intake ear on the Lt side, is that right?
I just got my engine running on this new set of carbs. The idle screws are only one turn out and it seems to be running rich coming off high idle. It's backfiring quite a bit out of the pipes. The engine is coastered and the air valve is not in the system. The carbs are balanced according to the Carbtune. Any ideas of what might be going on?
AceMcgyver is offline
post #2 of 5 (permalink) Old 07-30-2009, 04:13 AM
The Professor
lance328's Avatar
It is normal to run rich when choke is on. Your pilot screws could be set too low Factory is 1 5/8 turns, normaly incerasing the screw will stop the backfirng. If the carbs you got were from a vn700 the have 135 mainjets instead of 132.
Vent tube goes into the right ear.
Exhaust leaks will also cause popping.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #3 of 5 (permalink) Old 07-30-2009, 04:02 PM Thread Starter
Ahh, I thought on the idle screw it was in for lean and out for rich. Might be I have it backwards, I'll give it a try tonight. BTW, this is happening with the choke off.
post #4 of 5 (permalink) Old 07-30-2009, 04:42 PM
Send a message via AIM to Acid7711
I can assure you Lance is correct, he knows his stuff! Out for richer, in for leaner!
Acid7711 is offline
post #5 of 5 (permalink) Old 07-30-2009, 08:40 PM
The Professor
lance328's Avatar
Out does make it richer, there are three things that will cause popping:
1) too much fuel
2) not enough fuel
3) exhause leak
Since you have turned the pilot screw down to one turn and it happens when the choke is off that basicaly means you are not getting enough fuel. The choke actualy adds extra fuel and does not block off air flow.
The colortune can tell you one thing and your bike will tell you another.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
