Fuel mixture - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 2 (permalink) Old 07-21-2009, 09:48 PM Thread Starter
Fuel mixture
Not easy to get to...what type screwdriver are others using in that tight space?
Speaking of tight...how tight (how easy) are the screws to turn?
VoIPDoc is offline
post #2 of 2 (permalink) Old 07-21-2009, 09:55 PM
Calif Rider
weh44att's Avatar
Most of us use a very small screwdriver, something like the small jewelers type. The screws should be fairly easy to turn. Clockwise leans out the mixture. Be careful when you turn it in and seat the screw, do not over a lot of force when seating the screw. When it stops that is it, and then turn it out to set your mixture. Two to two and a half is about the right setting.
2004 25,500 miles
Led tail light enhancement
Homemade floor boards
Headlight modulator
Extra heat sink on R+R
R+R relocation
Homemade driver's backrest
Fused Stator
Mcct conversion-cost 4.50
Ride-on in tires
iridium plugs
coil pickups adjusted.
weh44att is offline
