Petcock is Screwed - Any Ideas - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 19 (permalink) Old 07-21-2009, 08:44 PM Thread Starter
Look at this!!!!
Any suggestions on this busted stem? When I took it apart it was completely clogged with crap. Any suggestions on getting a filter over this?
SyntaxJO is offline
post #2 of 19 (permalink) Old 07-21-2009, 09:41 PM
The Reanimater
jthill524's Avatar
Location: A Little Town Along I-5 in Northern California
http://www.cheapcycleparts.com/
51023-1308 TAP-ASSY,FUEL $53.57
http://partsfinder.onlinemicrofiche....=13&A=249&B=28
JaY
"Veronica"
2002 VN750 Vulcan
Rebuilt Engine
ACCTs lubed w/TOC Springs
Pick-up Coils Gapped at .018"
Splines Lubed
Deka MF AGM EXT15L Battery
NGK Iridium IX Spark Plugs
R/R Relocation Fix
New Rear Rack
Stock Seat Repadded
Ext-BackRest
jthill524 is offline
post #3 of 19 (permalink) Old 07-21-2009, 10:44 PM Thread Starter
Angry
such a shame - I just bought the rebuild kit...
SyntaxJO is offline
post #4 of 19 (permalink) Old 07-21-2009, 10:45 PM
The Professor
lance328's Avatar
Check your PM.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #5 of 19 (permalink) Old 07-22-2009, 01:01 AM
rider
global_recon's Avatar
hey j.
my petcock looked the same way, although mine still had the screen over the main tank pipe. my reserve tube was missing. you can buy the new petcock assembly or you could just install two inline fuel filters (or you could use whatever lance mysteriously pm'd you). picked mine up at o'reilly's... cheap... say $2.50 each or so. i also bought some extra fuel line to give me a little slack and then just rigged them up between the petcock and the carbs.
up to you, obviously, but since you just bought the rebuild kit you might want to go with the fuel filters. the only thing a replacement petcock is going to give you that you don't already have is screens over the main pipe and if i'm not mistaken, a very short reserve tank pipe with a screen.
paul
1991 vn750: 'for great justice'
http://www.globalrecon.org
follow my rides on twitter: http://www.twitter.com/globalrecon
global_recon is offline
post #6 of 19 (permalink) Old 07-22-2009, 09:44 AM
MO Rider
eberghold's Avatar
petcock rebuild
With all the funny buisness with the vacuum and petcock, has anybody just went with a strictly on/off with no vacuum needed? or is there such a thing. I would think without the plunger and diaphram parts that would get rid of that issue. Any thoughts? P.S. I do have a rebuild kit coming in today, hope it fixes the damn thing.
K&N Filters
No airboxes
New! Dunlop 110/90-19 front
150/90-15 rear
Aftermarket pipes
Iridium NGK plugs
"STUPIDITY SHOULD BE PAINFUL"
eberghold is offline
post #7 of 19 (permalink) Old 07-22-2009, 10:04 AM
If ya go that way, you'll have to remember to ALWAYS turn the fuel off when the bike isn't running. Otherwise you'll have fuell leaking all over the place. I do believe someone else here did that awhile ago.
As for adding inline filters, if you go that route, be sure they are filters that will give very little restriction, as there is no pump to push/pull the fuel through them, just gravity.
post #8 of 19 (permalink) Old 07-22-2009, 10:20 AM
The Professor
lance328's Avatar
Your 86' petcock has a "PRI" setting whichn means prime. It bypasses the vacuum diaphram and fuuel will flow without vacuum.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #9 of 19 (permalink) Old 07-22-2009, 03:31 PM Thread Starter
Hey thanks everyone. I have the main fuel filter - it's just the the reserve has been ripped off I guess. I'm gonna go for the in line fuel filter but I imagine that it'll clog again regardless (at least I'll keep everything out of my carbs though).
BTW - is the BIG O-RING in the petcock rebuild kit used for anything??
Thanks again.
SyntaxJO is offline
post #10 of 19 (permalink) Old 07-22-2009, 07:23 PM
Crobins365's Avatar
Thanks again.
There should be a semi-oval gasket between the top edge of the petcock and where it sits against the tank. If I remember correctly, I've used the large o-ring to serve as the semi-oval one.
C
Crobins365 is offline
