Decleration ?????? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 2 (permalink) Old 07-19-2009, 09:03 PM Thread Starter
Decleration ??????
Ok, So I just got my carbs back in rebuilt everythings good to go, but I am having a little hesitation at around 5500rpms. also from around 3500 or 4000 rpms real slow deceleration. The bikes back firing all the way through I believe just do to exshaust leaks no biggy, not thinking the two are related. if you have a opinion or anything please let me know cant figure out the decel. at all. thanks
raven8889 is offline
post #2 of 2 (permalink) Old 07-19-2009, 09:28 PM
93VN750's Avatar
You did make sure the carb vent tube is good to go? Sounds like a lean condition and if that tube is in anyway blocked, you'll starve for fuel.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
