Stuck float valve - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 07-16-2009, 01:33 PM Thread Starter
Stuck float valve
the float valve on my 1985 vn700 is stuck. I took the carburetor apart and the rear float valve came out fine, the front float valve, however, will not come out. I've tried spraying and soaking it with carb cleaner but the thing wont budge.
Any suggestions?
thanks
vinychase is offline
post #2 of 3 (permalink) Old 07-17-2009, 05:36 AM
Still stuck? I wonder if you could grab the valve needle from the grooves by small internal circlip pliers?
pappa is offline
post #3 of 3 (permalink) Old 07-18-2009, 04:04 PM Thread Starter
Thanks for the suggestion, i ended up drilling two holes at and angle on either side of the valve and prying it up with two scribes. The valve was really corroded, no wonder there was no gas in the carbs! lol
