Tired of lack of power... time to repair the phantom problem. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 22 (permalink) Old 06-23-2009, 12:43 PM Thread Starter
99vulcan750's Avatar
well, the last two weekend I have gone on 'trips'. Last weekend I went 175 miles, yesterday 220 miles. Both times the bike lacks the power it had last spring when I bought it, and has a very hard time over 5k RPMs and/or 75+. Sometimes it will do 80 mph, but if there is the slightest hill she drops 10-15 mph and struggles. if I am cruising at 70 at approx 3/4 throttle, she's pretty good. However if I go to full throttle she struggles and slow right down.
I have degoated, and drilled baffles, have the K&N stock replacement air filters, and I cleaned the carbs last year.
I am thinking that if I have to pull the carbs, I will just do the ear shave and have it all out at once.
Stock jets are still in there, my 138 and 140 jets are somewhere here but got a little mixed up in the move. the bike has been running this way since the last part of last fall. It has it's spurts where it will go 90, but that's only down hill...
After seeing Dave's post and thread, I am gonna ask for the much needed help...if i have time before work tonight, I will check the plugs- they will be replaced this weekend as will be ordering some online (NGK Iridium)
I work until Friday so the weekend will be my fixing time and won't have but a few hours each day.
any help would be great!
PS- I am at a higher altitude (4400') than I was in MI, but it still runs near the same way.. I think it's lean?
'99 VN750 with 8900 miles and growing (3,111 when I bought it 03-22-08)
Ear shave with Unipods
Drilled mufflers and degoat
TOC springs
N/C Street shield EX windshield
Jumbo Saddleman Highway Studded saddlebags
Willie and Max Saddlebag mounting kit
License plate turn signals
Home made sissy bar
Luggage Rack from Scoop
http://youtube.com/user/99vulcan750
99vulcan750 is offline
post #2 of 22 (permalink) Old 06-23-2009, 01:29 PM
fergy's Avatar
We'll all be interested in what your plugs look like. hang in there!
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #3 of 22 (permalink) Old 06-23-2009, 03:34 PM Thread Starter
here are the pics of the plugs...
Front:
Rear:
TOC springs
Home made sissy bar
post #4 of 22 (permalink) Old 06-23-2009, 03:41 PM
The Professor
lance328's Avatar
The plugs look good, it doesn't appear to be running lean.
A little hard to tell on the rear, are they tan or white?
Have you given her a good dose of Seafoam?
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #5 of 22 (permalink) Old 06-23-2009, 03:49 PM
fergy's Avatar
X2- the plugs look good, definitely not looking lean. Was the bike doing this before you left Michigan? How long? Since De-goating? Since carb cleaning?
Just trying to help put 2 and 2 together here. Does the bike have plenty of zip at lower speeds, but just when you hit high rpms does it get sluggish? Or is it sluggish throughout the range?
Fergy
2002 VN1500 Classic
SEAFOAM JUNKIE!
fergy is offline
post #6 of 22 (permalink) Old 06-23-2009, 03:55 PM Thread Starter
pretty good at slower speeds... once over 50 it slows down, takes 'forever' to get to 75 most of the time.
the plugs are the 10 year old stock plugs, so I will be getting new NGK iridium plugs.
the bike did this in Michigan, I believe since the degoat mid last summer, but I can't quite remember... I cleaned the carbs, but I didn't adjust the floats as I didn't know how and I couldn't figure out how to disassemble them. I am guessing the problem started after the degoat...
The rear plugs are sorta off-white with brownish/tannish tips...
On side note- it has the MF battery, and i tried 138 jets this spring in MI with no change in performance... I am gettign about 30-35 mpg at speeds of 65-75...
TOC springs
Home made sissy bar
post #7 of 22 (permalink) Old 06-23-2009, 04:03 PM
The Professor
lance328's Avatar
Install the Iridiums and and see what happens, new wires and caps would be a good thing also.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #8 of 22 (permalink) Old 06-23-2009, 04:03 PM
fergy's Avatar
It might just be a couple of your plugs have gone bad. That can happen and still look normal. I'd be anxious to see how she runs with the new iridiums in her. Then go from there.
If it started right after the de-goat, it would be easy to think something about the de-goat is causing it. But I've had things go bad, untouched and spent days trying to figure out what I did. Had my carbs off my kz1000 about 4 times in 2 weeks trying to figure out what I had done, cause the bike ran like crap after I put them back on the first time. Turned out a couple plug wires just quit on me. Hadn't touched them in all the process. Ordered new caps and wire and installed it and the bike ran like a dream again. Just bad timing.
Fergy
2002 VN1500 Classic
SEAFOAM JUNKIE!
fergy is offline
post #9 of 22 (permalink) Old 06-23-2009, 05:02 PM
Hey 99vn you need to update your profile. You`re out west here in God`s country, and your profile notes say you are still back in the Sault !
If you are looking to save a few bucks on new plug wires, this post of skaldings may be of interest to you. https://www.vn750.com/forum/showthread.php?t=11031
post #10 of 22 (permalink) Old 06-23-2009, 06:50 PM Thread Starter
thanks! updated my signature, but not the rest...
TOC springs
Home made sissy bar
