can't get her to idle on her own. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 06-21-2009, 07:00 PM Thread Starter
I have an 85' vulcan 700 and she is my first bike, I am mechanically inclined, so fixing her is not an issue as long as I have my manual. But the book doesn't troubleshoot everything. My problem is after she starts and I release the throttle all the way until it stops the bike quits, if I manually idle the bike with the throttle(1/8 of an inch before it stops) it stays idling, but if touch the throttle and rolls toward the front of the bike(where it stops) the bike dies. Any tips on how to fix this problem. And also, this is a great forum with a lot of knowledgable folks. Thanks for letting me register with this forum.
vn700inmaine is offline
post #2 of 14 (permalink) Old 06-21-2009, 08:01 PM
Do you know about the black knob on the left below the fuel tank? That is the idle adjuster. Might give that a try.
post #3 of 14 (permalink) Old 06-21-2009, 08:18 PM
The Professor
lance328's Avatar
Set the idle @ 1100 rpm after it has reached operating temp.
Welcome to the fun house!!
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #4 of 14 (permalink) Old 06-21-2009, 08:50 PM
Welcome to the forum vn700inmaine, from western Canada. Let us know if setting that idle adjustment knob works.
https://www.vn750.com/forum/11-vn750-general-discussion/9127-top-ten-items-you-would.html
post #5 of 14 (permalink) Old 06-21-2009, 09:47 PM
Welcome to the forum, I didn't notice it was your first post.
post #6 of 14 (permalink) Old 06-21-2009, 10:58 PM Thread Starter
Thanks everyone, I tried adjusting the idle before posting my first post and it didnt seem to keep the bike from quitting, so I figured it might have been something else, but I kept saying to myself that the idle was not correct but wasn't 100% sure so I figured I'd ask the people that know more about my bike than I do. I'll tinker with the idle some more and hopefully get that problem to stop. Thanks for the info.
post #7 of 14 (permalink) Old 06-22-2009, 10:39 AM
fergy's Avatar
Welcome to the group! I'm assuming you are using the choke while starting the bike cold, right? Once the bike has warmed maybe 30 seconds, and you roll the choke off it dies? Or does it run on it's own at all with the choke? Just trying to clarify what you are telling us. Let us know!
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #8 of 14 (permalink) Old 06-23-2009, 01:49 PM Thread Starter
Yes, the choke is on and after a couple minutes the bike idles on it's own, it stays running without a problem, except when you roll the throttle forward(where it stops) it quits-if I roll the throttle slightly towards me, it will idle. I still have to fine tune the idle, so hopefully that's the cause to the problem.
post #9 of 14 (permalink) Old 06-23-2009, 03:07 PM
How long was this bike setting?? Here I go again with the dirty carb needing cleaning. I believe that the fuel delivery from the carb to the cylinder is the problem. imo
post #10 of 14 (permalink) Old 06-23-2009, 03:29 PM
fergy's Avatar
Sounds like dirty carbs. You know me... have you bathed her in seafoam yet? (the tank, I mean)
Fergy
2002 VN1500 Classic
SEAFOAM JUNKIE!
fergy is offline
