Flooding out at Idle - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 06-04-2009, 09:24 PM Thread Starter
Job
Hey guys,
My 1985 VN 750 (86 engine) is flooding out at idle. It is blowing black smoke but runs fine at 5k rpm. It leaked a big pile of gas all over the garage and the fuel is not shutting off when the engine is off.
Any thoughts?
JOB
Job is offline
post #2 of 5 (permalink) Old 06-04-2009, 10:18 PM
The Professor
lance328's Avatar
Sound like stuck float valve, is your petcock set to PRI or On?
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #3 of 5 (permalink) Old 06-05-2009, 05:35 AM
Alatri's Avatar
Petcock Seal
Could it be that his petcock seal and oring is old, worn, and shot.
I had this problem, changed them and it fixed the leakage,
found a 18 dollar kit for the two o-rings and seal from a canadian company,
if you think that this might help, let me know, and i'll go threw my visa bill to find the company's name and website.
Alatri is offline
post #4 of 5 (permalink) Old 06-05-2009, 05:51 AM
The Professor
lance328's Avatar
It could be the petcock, but if he has the petcock set on "PRI" it bypasses the shutoff. If he has a stuck float valve it will drain the tank down to the reserve level.
If the petcock o-ring has gone bad and a piece made it to the float valve the result would be the same.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #5 of 5 (permalink) Old 06-05-2009, 10:29 PM Thread Starter
Job
The petcock is in the on position. So it is a stuck float, any thoughts on how to unstick it and keep it that way?
Job is offline
