drain - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 05-17-2009, 03:28 PM Thread Starter
drain
where is the drain located on the vn750 carbs, mainly the carb on the right side as you sit on the bike
joeptc is offline
post #2 of 3 (permalink) Old 05-17-2009, 04:22 PM
It is at the bottom of the carbs. It is a straight edge screw type. Unscrew it and the fuel will drain.
post #3 of 3 (permalink) Old 05-17-2009, 04:52 PM
Love My Baby
rubyrick's Avatar
You might want to turn your fuel valve off and run the bike until it stalls out before you drain the carbs. Less messy that way.
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
LED license plate frame
X
rubyrick is offline
