Question about hesitation when accelerating - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 05-10-2009, 04:04 PM Thread Starter
First of all I use Seafoam on a regular basis. I still fell some hesitation in the throttle when I 1st get on it at lower RPM's (3k-6k). It does pick up eventually when it gets above 6k. Does this sound more like an air/fuel adjustment thing? or more of a dirty carb issue. I've also tried Premium fuel and it doesn't seem to make a difference.
If I get out on an open stretch and redline it (in 4th gear) then let off the throttle, I will get a loud backfire sometimes, is that also normal?
post #2 of 4 (permalink) Old 05-10-2009, 09:13 PM
The Professor
lance328's Avatar
Pull your plugs and let us know what color they are.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #3 of 4 (permalink) Old 05-17-2009, 07:39 PM Thread Starter
OK here is what I found when pulling the plugs. The ceramic on the rear right side plug is hardly dirty, all the others seem about the same.
This is the left side plugs (front / rear) Click image for larger version
This is the right side plugs (front / rear) Click image for larger version
Name:	plugs right.jpg
post #4 of 4 (permalink) Old 05-18-2009, 12:00 AM
The Professor
lance328's Avatar
Check the spark on all four, looks like your right rear may have weak spark.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
