Removing A/F mixture plug - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 05-05-2009, 01:09 AM Thread Starter
basherbob's Avatar
Is it possible to remove the plugs without removing the carbs from the bike? the left /front carb looks tricky since is looks aimed at the cylinder.
basherbob is offline
post #2 of 5 (permalink) Old 05-05-2009, 01:19 AM
The Professor
lance328's Avatar
Some have removed it with a dental pick.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #3 of 5 (permalink) Old 05-05-2009, 07:50 AM
Yes it is, I did. There is more room between the screw and the plug then I thought. You just have to work at it with small pointy instruments.
post #4 of 5 (permalink) Old 05-05-2009, 08:58 AM
Thumbs up
It is a little tight, but when I did mine I used a dremel tool with a small pointed bit to grind a hole in the center, then popped it out with the point of a sharp pick. I can tell you, after reading many of the posts on how to do this, I expected a soft lead plug. Mine was a hard little plug that appeared to be aluminum. With out the dremel, I could not get a hole by just working a sharp pick. Good luck
ratuck
Eldersburg, Maryland
2003 VN750
3500 Miles
MF AGM Battery
Willie & Max Compact Slant Bags
Saddleman Explorer Seat
Vance & Hines Cruzers
Kawasaki Rear Luggage Rack
Memphis Shades Shooter Windshield
Oversized Grips
Spline Lube
ratuck is offline
post #5 of 5 (permalink) Old 05-05-2009, 08:01 PM
Undercover Sportbiker
AJCruzin's Avatar
Yep, you just have to have small hands.
AJCruzin is offline
