Anyone used KBS coatings? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 04-29-2009, 08:31 AM Thread Starter
Newb with a Bullet!
krebsne's Avatar
Anyone ever used this product? I did a search on it and came up with nothing, but some people mentioned other tank sealants dissolving over time and mucking with the carbs.
Thoughts? Experience? Anecdotes?
http://www.kbs-coatings.com/KBS-Cycl...-Kit_p_31.html
krebsne is offline
post #2 of 11 (permalink) Old 04-29-2009, 11:06 AM
First I've heard of the stuff. Anything would be better than Kream, I'd think, but I'd prolly still go with the electrical process mentioned elsewhere, myself.
Jim
J.D.
Kerrville, TX
'95 Vulcan 750 "Therapy II",
aka "Raggedy Ann"
'95 VN750 project
'03 VN800B "The Little Black"
'04 VN800E Drifter project
'93 VN1500A custom project
VROC #16185
GCVROC #33
J.D. is offline
post #3 of 11 (permalink) Old 04-29-2009, 12:10 PM
The Reanimater
jthill524's Avatar
Location: A Little Town Along I-5 in Northern California
Can't say I have but reading the Discription has me confused. I'll highlight where..........
Gold Standard Fuel Tank Sealer is specifically formulated to stop rust and corrosion by forming a tough, fuel impervious coating while simultaneously sealing small pinholes and weld seams.
This kit contains our KBS AquaKlean (a water-based, heavy-duty, cleaner/degreaser) and KBS RustBlast (a powerful rust remover/metal etch) to obtain a permanently sealed, rust-free fuel tank. These KBS prep products are formulated with a unique Oxygen-Block Technology which reduces the occurrence of flash rust by over 80% and extends rust-free storage times by leaving a temporary protective coating in addition to a zinc phosphate film.
So is it permanent or temporary???
JaY
"Veronica"
2002 VN750 Vulcan
Rebuilt Engine
ACCTs lubed w/TOC Springs
Pick-up Coils Gapped at .018"
Splines Lubed
Deka MF AGM EXT15L Battery
NGK Iridium IX Spark Plugs
R/R Relocation Fix
New Rear Rack
Stock Seat Repadded
Ext-BackRest
jthill524 is offline
post #4 of 11 (permalink) Old 04-29-2009, 05:23 PM
That's what had me wondering, too.
Jim
J.D.
Kerrville, TX
aka "Raggedy Ann"
'95 VN750 project
VROC #16185
GCVROC #33
J.D. is offline
post #5 of 11 (permalink) Old 04-29-2009, 05:53 PM
The temporary coating is just to protect the metal while the process is being done. Once dry , the coating itself becomes the rust protector.
"These KBS prep products are formulated with a unique Oxygen-Block Technology which reduces the occurrence of flash rust by over 80% and extends rust-free storage times by leaving a temporary protective coating in addition to a zinc phosphate film."
You all highlighted the wrong words....lol
Another new one on the market is Stampede tank liner :
http://tinyurl.com/dlf7dm
(well has been used industrialy for 20 years, now available for motorcycle tanks )
post #6 of 11 (permalink) Old 04-29-2009, 05:55 PM Thread Starter
Newb with a Bullet!
krebsne's Avatar
So a guy locally has an unused KBS kit for sale for $25. Should I get it and put it in the tank I am repainting or not needed?
krebsne is offline
post #7 of 11 (permalink) Old 04-29-2009, 06:11 PM
Do you have any rust in the tank now?
Go into the Verses, down close to the bottom of the table of contents, and read the 2 or 3 threads on removing rust from a tank, and the electrolysis method for sealing the tank.
Then you have enough info to compare the KBS kit, and decide which you want to do, if any is needed.
post #8 of 11 (permalink) Old 04-29-2009, 06:22 PM Thread Starter
Newb with a Bullet!
krebsne's Avatar
Pardon my newb-ness, but where are the Verses? (Presumably the Vulcan Verses.) I've heard of them. Aren't they on the VN750 Yahoo group or am I mistaken?
krebsne is offline
post #9 of 11 (permalink) Old 04-29-2009, 06:35 PM
The Reanimater
jthill524's Avatar
Nope....... because it also says....
So adding These KBS prep products....
Makes Me still ask the question.
Is it permanent or temporary?
Because if This Kit contains just a Prep Product then it's not a finish/ing product.
JaY
"Veronica"
2002 VN750 Vulcan
Rebuilt Engine
Splines Lubed
R/R Relocation Fix
New Rear Rack
Stock Seat Repadded
Ext-BackRest
post #10 of 11 (permalink) Old 04-29-2009, 06:48 PM
..Because if This Kit contains just a Prep Product then it's not a finish/ing product.
You are just reading too much into this. They are selling the "Gold standard fuel tank sealer" ALONG with a kit that contains the prep stuff (even some gloves to wear it seems)
It should have probly said "kit also contains" .. The prep stuff uses the temporay rust inhibitor which is want you would want if your pouring water into the tank...
