engine problems!!!!!!!!!!!!11 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 2 (permalink) Old 04-23-2009, 06:13 PM Thread Starter
have a vn 750 l reg 94 model,
runs fine when cold and then revs fluctuate and cuts out when it heats up(or uses fuel in carbs?)
but starts and idles fine only when in gear and let oit clutch does it cut out- wven on centre stand with no strain on engine!!!
anyone have any ideas???
wrighty123 is offline
post #2 of 2 (permalink) Old 04-23-2009, 07:26 PM
The Professor
lance328's Avatar
Check the plunger on your side stand switch, it may be sticking. Run plenty of Seafoam through the system and make sure ALL ground wires are tight. Check vacuum hose to petcock for cacks/leaks and check for leaks around carb boots. Check carb vent hose make sure it is not bottomed out.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
