Pictures Showing How to Build a Manometer - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 04-22-2009, 09:51 PM Thread Starter
Crobins365's Avatar
Smile Pictures Showing How to Build a Manometer
https://www.vn750.com/photopost/showgallery.php?cat=657
I decided to rebuild my manometer and so thought I'd take some "how to" pics for anyone who is interested. Please note two things: I put the oil in the tubing tonight, so it hasn't finished settling out yet; ergo, I won't be able to actually use the thing until at least tomorrow. At that point, I'll take photos about how to seet up the t-connector and what the oil levels look like as you're trying to get the carbs in sync with each other. I'll probably also move my pics of the idle adjust and carb sync screws into this album as I move along.
Let me know if you have any questions or if anything is unclear. I can write better instructions if needed.
C
Crobins365 is offline
post #2 of 11 (permalink) Old 04-22-2009, 10:10 PM
I bilt one of them. All I managed to do was suck the oil out into the intake and out the exhaust. I hope you do better than that.
post #3 of 11 (permalink) Old 04-22-2009, 10:20 PM
do two vacuum gauges of the same type get an accurate enough reading to synch our carbs properly
post #4 of 11 (permalink) Old 04-22-2009, 10:21 PM
Yes, but this is cheaper.
post #5 of 11 (permalink) Old 04-22-2009, 10:22 PM
The Professor
lance328's Avatar
Did you hook up both lines before you started the engine? I made the same one and have had no problems.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #6 of 11 (permalink) Old 04-22-2009, 10:23 PM
I think my problem was that the oil was too light. I used ATF.
Yes I hooked up at the same time.
post #7 of 11 (permalink) Old 04-22-2009, 10:24 PM
The Professor
lance328's Avatar
You will not get the same accuracy but it will get you close enough.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #8 of 11 (permalink) Old 04-22-2009, 10:26 PM
good deal ,thanks Lance
post #9 of 11 (permalink) Old 04-22-2009, 10:29 PM
me and a friend of mine have one each already ,now that's cheap and i don't have to work at it lol
post #10 of 11 (permalink) Old 04-22-2009, 10:35 PM
i thought by the title of this thread that it was going to be a gauge with steven urkel from family matters on one end and stephan ur'kel on the other!!
bigrepp61 is offline
