Stuck float - Page 3 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 7Likes
post #21 of 25 (permalink) Old 05-22-2020, 09:29 AM
Originally Posted by MSattler View Post
No worries! So replace the collars at the hose, and check the fuel level then potentially pull the carbs. What is the head gasket check? I can check the oil in the site glass, to see if it is a milkshake color...
Yes, if it's milkshake when cold, it has a problem. Just remember, this engine has milkshake just after starting, until full warm up.
Not running, water/oil will settle out and separate, so might have to drain it to see.
MSattler likes this.
post #22 of 25 (permalink) Old 05-22-2020, 02:48 PM Thread Starter
MSattler's Avatar
The oil looked nice and dark (changed it 40 miles ago), with no oil/water separation. What would you inspect next?
'08 Road King Classic
'86 VN750:
Ear Shave, K&N Filters, Mean Streak Seat, AGM battery, Blue Wire Mod, Pick-up Coil Mod, Timing Advance Mod, NGK Iridium Plugs and Wire, LEDs, Bed Liner Paint Job, Over-sized Tires, New Brakes, New Fork Seals, Progressive Springs, Kick Stand Mod, Highway Pegs, 40/140 No Shims, Vance & Hines Exhaust, New Grips, Extra Wide Emgo Handle Bars
John 8:44, REV 2:9, REV 3:9 - If you were kicked out of 109 bars, would you think the problem was you, or the 109 bars?
MSattler is offline
post #23 of 25 (permalink) Old 05-22-2020, 07:28 PM
Check spark plugs after a little running? Look for water droplets.. or steam cleaned look.
Oil dark at 40 miles? Is it Castrol?
post #24 of 25 (permalink) Old 05-26-2020, 06:18 PM Thread Starter
MSattler's Avatar
Yeah, I used castrol. After it got to a 1/4 of a tank, it stopped leaking, and the coolant stopped leaking. I just filled it up, no more flooded cylinder, no more leaking fuel. I just went 40.7mi today and the tank is still full. Looks like the seafoam has done it again. I need to replace the coolant that has leaked out though.
'86 VN750:
MSattler is offline
post #25 of 25 (permalink) Old 05-26-2020, 06:36 PM Thread Starter
MSattler's Avatar
Back right plug
Front right
Back left
Now itís lean?
'86 VN750:
MSattler is offline
