Here we go "AGAIN" - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 42 (permalink) Old 05-13-2020, 03:42 AM Thread Starter
As most of you know this bike has given me trouble right from the get go. Recently it was taken apart for some repairs(coolant in the oil) so i split the cases to give it a good clean and make sure everything was in tip top shape. New mech seal , new gaskets all round etc. I had it running before i took it apart so this has left me stumped. Right here goes. Went to start the bike after the rebuild and nothing. Cranks and cranks with the odd shotgun bang 😁 ( scares the **** outta me everytime). But no start. Battery is brand new mf battery, timing is spot on 305* as i wont make the same mistake twice. Everything lines up with all the marks. Starter is perfect. Good blue spark from the plugs. My carbs do need a little work (float stuck i think) but there is fuel in the bowls after i prime them. Here the funny part. After cranking the plugs still look dry. So next step. Try starter fluid. Few squirts of starter fluid and still nothing. Anyone any ideas why it wont start. Im at my withs end with this bike. Im at the stage of just getting rid of it. Any help much appreciated.
Will750 is offline
post #2 of 42 (permalink) Old 05-13-2020, 06:48 AM
Was going to say, get fuel into it, but you did and starting fluid too.
Airbox clogged with old filter foam?
Getting good compression?
post #3 of 42 (permalink) Old 05-13-2020, 07:01 AM Thread Starter
the bike has the ear shave done to her. So get this. Just went out. Took tank off last night and drained the bowls. Sprayed starter fluid into it and she ran for about a second. Put a small bit of fuel in the bowls, gave it a shot of starter fluid and she fired up. But only with full choke and full throttle. Even then it sounded like she was bogging down. Any ideas what could cause this. Im lost to be honest. But at least it ran even if it was bogging
Will750 is offline
post #4 of 42 (permalink) Old 05-13-2020, 07:12 AM
Sounds like it's just not getting enough fuel. Make sure the petcock is flowing.
I'll put gas in a Windex bottle and force feed if I have to. Have to watch those lean backfires though.
post #5 of 42 (permalink) Old 05-13-2020, 07:22 AM Thread Starter
yeh it was backfiring like crazy. Could it be all down to a carb problem. Plugs were wet when i checked just after she ran
Will750 is offline
post #6 of 42 (permalink) Old 05-13-2020, 07:32 AM
Well getting it fired may have gotten the fuel flowing.
Backfires can be due to being lean, opening the throttle and giving it too much air, and low voltage to the CDI can cause backfire.
post #7 of 42 (permalink) Old 05-13-2020, 07:38 AM Thread Starter
ok thank you spockster. Im going to rebuild the carbs anyhow so we will see what happens. Thanks for you help.
Will750 is offline
post #8 of 42 (permalink) Old 05-13-2020, 07:50 AM
Leaks around the carb boots can create a lean condition, might be worth checking.
Vulcan slang for newcomers
Service Manual Download
Thorn is online now
post #9 of 42 (permalink) Old 05-13-2020, 08:30 AM Thread Starter
i will make sure to check it. Thanks for your input
Will750 is offline
post #10 of 42 (permalink) Old 05-16-2020, 02:28 PM Thread Starter
Ok so a range of new problems arised. Got the bike starting first push of the button after i squeeky cleaned the carbs. Now the bloddy thing wont rev passed 2k. It started by firing only on the rear cylinder but once i got this sorted and running it startrd popping like crazy. I also noticed that the vacuum slides are vibrating like crazy. I have a leaky petcock but even with the tank off and just the fuel in the bowls it does the same. It idles fine for a bit but if i even look at the throttle is dies. Any one any ideas?
Will750 is offline
