Carb Sync - Page 2 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 6Likes
post #11 of 14 (permalink) Old 05-02-2020, 11:06 PM
Originally Posted by DenverDiesel View Post
It removes the protective natural passive aluminium oxide layer and allows it to corrode until a new layer is formed. If any vinegar is left on the metal it will not form that protective layer.
Same like using chlorine or steel scrubbing pads with stainless steel can damage the passive oxide layer and make it corrode.
That last bit I know because I know a man that tried to clean his DeLorean with a scrubbing pad. Turned into a very expensive and ugly mess to fix.
I always advise a thorough neutralizing rinse. Hadn't considered passive layers. I do warn it will darken aluminum somewhat, but it's acceptable in some applications. Makes brass jets look new. Eats corn syrup concrete like butter.
post #12 of 14 (permalink) Old 05-03-2020, 12:07 AM Thread Starter
MSattler's Avatar
Iím more concerned with everything being cleaned, than the color of the carbs. I soaked it in a baking soda, then sprayed it liberally with wd-40
'08 Road King Classic
'86 VN750:
Ear Shave, K&N Filters, Mean Streak Seat, AGM battery, Blue Wire Mod, Pick-up Coil Mod, Timing Advance Mod, NGK Iridium Plugs and Wire, LEDs, Bed Liner Paint Job, Over-sized Tires, New Brakes, New Fork Seals, Progressive Springs, Kick Stand Mod, Highway Pegs, 40/140 No Shims, Vance & Hines Exhaust, New Grips, Extra Wide Emgo Handle Bars
John 8:44, REV 2:9, REV 3:9 - If you were kicked out of 109 bars, would you think the problem was you, or the 109 bars?
MSattler is offline
post #13 of 14 (permalink) Old 05-08-2020, 01:02 PM
Jason Pittenger's Avatar
Just make sure they open at the same time you turn the throttle
That is the definition of syncing the carbs...
Completed modifications:
Planned modifications:
Jason Pittenger is offline
post #14 of 14 (permalink) Old 05-08-2020, 01:25 PM Thread Starter
MSattler's Avatar
Haha. Youíre not wrong Jason. I was referring to the manometer though
Jason Pittenger likes this.
'86 VN750:
MSattler is offline
