I just want to be sure I’m getting all of this right. I just did the ear shave mod and pulled out all the emissions stuff so there’s a lot of left over parts and I want to be sure I didn’t miss anything getting put back on lol. So below I’ve listed everything that has been done. Please let me know if I did anything incorrectly or missed something.
1. The carb has many vacuum ports and hoses. The two gas lines go to the gas ports on the Petcock. There is a vacuum line that goes from the middle/bottom of the petcock to a vacuum port on the front/left carb. The vacuum port on the rear/right carb gets plugged. The two hoses that come to a T at the top of the carbs go to a emgo filter with the crankcase hose.
2. The two reed valves are capped off with rubber plugs and clamp.
3. The two ports coming out of the bottom of the fuel tank are capped off.
Anything I missed or didn’t do right?
