Carb fuel intake plastic - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
  • 1 Post By macdj250
post #1 of 7 (permalink) Old 01-07-2020, 03:38 PM Thread Starter
macdj250's Avatar
Carb day for my new build was yesterday...aside from a few side of the road fixes from the previous owner that have been corrected, I have one remaining problem.
On the duel carb float bowl assembly. There is a plastic elbow that fits over a brass inlet. Two; one into each individual bowl. One of the plastic elbows is missing.
The previous owner ran a fuel line directly over the brass inlet. This stretched and ruined the fuel line when removing it from the inlet.
I have searched this site “fuel bowl inlet” “fuel bowl elbow” fuel bowl “intake”. Carb bowl inlet. Carb bowl elbow. Etc. unable to find information on these.
The diagrams on parts warehouse and partszilla do not have a part number or even a label for it, as if it solely a part of the bowl assembly.
Does anyone know the part number or numbers to locate replacement.
I vaguely remember reading about a Harley Davidson part that allowed more fuel flow. And replaced the brass inlets with a single elbow part. I believe it was in one of the ear shave modification feeds. But I’m unable to locate that in the 1000 different ear shave posts. Click image for larger version
ID:	47147Click image for larger version
1995 Vulcan 88 (1500)-complete rebuild-oem
1981 GS850GL-complete rebuild-oem
1988 Vn 750-current project-bobber
1985 Madura 750-next in line project.
rebuilt 5 other bikes, but don't own them anymore
macdj250 is offline
post #2 of 7 (permalink) Old 01-07-2020, 03:40 PM Thread Starter
macdj250's Avatar
More pictures.
ID:	47149   Click image for larger version
macdj250 is offline
post #3 of 7 (permalink) Old 01-07-2020, 09:15 PM
I've posted some links to the elbow a few times, but I don't think it would be in any of the earshave posts. If you shop around, you can get those pieces for about $8 each, but I've seen them as high as $44. If you keep digging, you can probably beat the prices on the links below, shipping is nuts. It's just a 90 press-in 5/16" fuel inlet.
Someone had a thread going on this about two months back.
Forum search: fuel inlet
https://www.vn750.com/forum/gtsearch.php?q=fuel%20inlet
5/16 fuel inlet 90
https://www.denniskirk.com/drag-spec...SABEgKPqfD_BwE
https://www.summitracing.com/parts/t...SABEgK7efD_BwE
https://cv-performance.com/harley-fuel-max-inlet-elbow
post #4 of 7 (permalink) Old 01-07-2020, 09:51 PM Thread Starter
macdj250's Avatar
Perfect. Exactly what I was looking for. Thank you!
ubertalldude likes this.
macdj250 is offline
post #5 of 7 (permalink) Old 04-22-2020, 09:18 PM
MSattler's Avatar
I love this place. I just broke the plastic nipple off trying to get this stupid carb out of a bike without the ear shave. You guys came through again
'08 Road King Classic
'86 VN750:
Ear Shave, K&N Filters, Mean Streak Seat, AGM battery, Blue Wire Mod, Pick-up Coil Mod, Timing Advance Mod, NGK Iridium Plugs and Wire, LEDs, Bed Liner Paint Job, Over-sized Tires, New Brakes, New Fork Seals, Progressive Springs, Kick Stand Mod, Highway Pegs, 40/140 No Shims, Vance & Hines Exhaust, New Grips, Extra Wide Emgo Handle Bars
John 8:44, REV 2:9, REV 3:9 - If you were kicked out of 109 bars, would you think the problem was you, or the 109 bars?
MSattler is offline
post #6 of 7 (permalink) Old 04-24-2020, 06:52 AM
1RadCJ5's Avatar
Some brilliant minds in this forum. Unbelievable info in here. I tip my hat to all of you! Mike
1RadCJ5 is offline
post #7 of 7 (permalink) Old 04-24-2020, 09:24 AM
MSattler's Avatar
So is it necessary to get a tap and die to pull out the inlet? It looks to have a knurled ring. I get the new ones are just press in, that seems easy enough.
'86 VN750:
MSattler is offline
