More Power? - Page 2 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
post #11 of 14 (permalink) Old 05-22-2019, 10:27 PM
I'm a rider
One1's Avatar
The fastest VN750 I've ridden and owned had full stock exhaust. No amount of jetting changes or tinkering has ever compensated enough for the loss of backpressure. This engine LIKES backpressure.
1981 KZ750
1988 Vulcan VN750 (red)
2005 Vulcan VN750 (silver)
(2) 1994 Vulcan VN750 (red)
One1 is online now
post #12 of 14 (permalink) Old 05-23-2019, 06:14 PM
There is no known way of getting more power out of the Vulcan 750 engine, and it does not need any more power. IF you could get more power out of it, it would put more stress on the engine and shorten it's life. If you need more power, get a bike that makes more power stock.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #13 of 14 (permalink) Old 05-23-2019, 09:30 PM
Jason Pittenger's Avatar
I'm not so sure. I did an earshave, and I'm open pipes after the GB. I rejetted from 38/132 to 40/143. I'm getting slightly better mpg this year vs last year (45.5 vs 44.1 average over several tanks).
My new jets are giving me 11% more fuel on the pilot and 17% more fuel on the mains. If my MPG rose, it must be more efficient. If it was all simply cosmetic, than my MPG should have dropped nearly 11% instead of rising 3%.
If it still runs well with 11-17% more fuel (and sputtered lean without rejetting), then it must be taking in more air than before. If it's taking in more air, it must be producing more power. Maybe not 17% more. I might be rich at WOT. But 5-10% more.
Unfortunately, no one has done a dyno run before and after on the same bike to prove it.
All I know is the extra fuel must be going somewhere, and it isn't going to low MPGs.
Completed modifications:
Planned modifications:
Jason Pittenger is offline
post #14 of 14 (permalink) Old 05-23-2019, 09:36 PM
It's not back pressure specifically, but the timing of the pulses out of the exhaust. Show me exhaust pipe diameter changes significantly, this ends and negative pulse back up the pipe. This negative pulse helps to scavenge through remaining exhaust out of the cylinder. The goats belly is part of the tuning for this.
The stock exhaust has a diameter change right at the exit of the goat's belly. Removing the mufflers puts a very large diameter change at the same location. The tuning of the exhaust pulses does not change with removing the mufflers. However, the back pressure is reduced significantly.
I didn't really notice a change from the back pressure, until I had also done an ear shave. That was when I noticed that putting the mufflers back on, resulted in it becoming too rich to run properly.
In reality, no engine in the world likes back pressure. It's all about pulse tuning in the exhaust. The less restriction you have in the exhaust, the better. The engine has to work to push the exhaust out of the engine, so you might as well make its job easy.
