Carburetor Vacuum Leak - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 04-22-2019, 02:29 PM Thread Starter
Jason Pittenger's Avatar
I have a few questions about the attached picture.
While cleaning my carbs, I took this cover off from my rear (right side) carb.
I realized I didn't need to remove it, so I put it back on and did not remove the front (left side) one.
Now I have a vacuum leak from this cover.
The screws are tight, but I can change the sound of the air woosh sound by pushing on the cover.
Also, spraying this cover with fluid causes the engine to bog down.
First question, what does this assembly do?
Second question, is 92055A part of this assembly?
It's not clear where it is supposed to go.
I don't recall seeing one when I took it apart.
I may have put it around 13091 when I reassembled...that could be a problem.
Third question, can I put the cover on an seal the cover with RTV?
Edit: The picture is hard to see.
Go to https://www.kawasakipartshouse.com/o...rburetor-parts for a zoomable diagram.
The parts in question are 223, 14024A, 92055A, 92081C and 43028.
Completed modifications:
Planned modifications:
Last edited by Jason Pittenger; 04-22-2019 at 02:45 PM. Reason: Picture too small, and hard to see
Jason Pittenger is offline
post #2 of 5 (permalink) Old 04-22-2019, 05:38 PM
That's the Coast Enricher. Take the cover off and see if everything is in place correctly.
post #3 of 5 (permalink) Old 04-23-2019, 04:34 AM
I had problems with the diaphragm in there on both carbs several years ago. They were melted. I believe it was caused by ethanol gas. Part# 43028 DIAPHRAGM,AIR CUT VALVE I believe the edge of that diaphragm is what seals the cover. If not, there would be an O-ring behind the cover. In fact there is a tiny O ring behind the cover. Remove it again and check the parts diagram and make sure you have all the parts. And check the condition of the diaphragm. If it looks good, make sure it is seated in the groove all the way around.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #4 of 5 (permalink) Old 04-23-2019, 08:03 AM Thread Starter
I started it up last night and reconfirmed it had a leak at that cover by spraying it.
I pulled the cover and discovered the o ring WAS missing. Oops! It must have fallen out when I opened it during cleaning, and didn't notice. I had an extra of that size so I put one in and reset my idle screws.
I must have flooded the engine with the spray because it wouldn't start. I got some nice fire balls out the exhaust, and a few loud bangs that I thought was going to blow off the exhaust! It was exciting...
I thought you could clear out a flooded engine by cranking it with a full throttle, but alas it just kept banging and spitting fire. We'll see how it starts/runs today.
Edit: It started right up with a little choke and 2 and 1/2 turns on this screws. I backed out to 3 and 1/2. 4 and 1/2 turns caused a dip in the idle so I went back to 3 and 1/2. I rode it around the block and it seems healthy. It's too cold to ride to work though today. I should be able to ride it to work tomorrow.
Here is a video of it idling in my garage. With good headphones, it sounds just like you're standing in my garage.
https://photos.app.goo.gl/5cgKYfoixw6oBEWn8
Thanks!
post #5 of 5 (permalink) Old 05-07-2020, 10:06 AM
MSattler's Avatar
deleted because posted in err
'08 Road King Classic
'86 VN750:
Ear Shave, K&N Filters, Mean Streak Seat, AGM battery, Blue Wire Mod, Pick-up Coil Mod, Timing Advance Mod, NGK Iridium Plugs and Wire, LEDs, Bed Liner Paint Job, Over-sized Tires, New Brakes, New Fork Seals, Progressive Springs, Kick Stand Mod, Highway Pegs, 40/140 No Shims, Vance & Hines Exhaust, New Grips, Extra Wide Emgo Handle Bars
John 8:44, REV 2:9, REV 3:9 - If you were kicked out of 109 bars, would you think the problem was you, or the 109 bars?
MSattler is offline
