Testing Ear Shave, Rough at high RPM - Page 2 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 6Likes
post #11 of 54 (permalink) Old 03-31-2019, 04:53 PM Thread Starter
Jason Pittenger's Avatar
Hmmm, is one alignment mark width off enough to be the sole cause of a vacuum leak?
I do know that both leak, and only one is slightly misaligned.
Completed modifications:
Planned modifications:
Jason Pittenger is offline
post #12 of 54 (permalink) Old 03-31-2019, 10:09 PM
Location: southern, western, middle Tennessee backwoods
Yes.
If there are no cracks in the rubber and no gouges in the aluminum and the boots are correctly located and the clamps tight, then there shouldn't be any leaks.
The boots must be lined up right, front to front and rear to rear.
"I need yo clothes, yo boots and yo motocycle."- Uncle Bob
roadpouring is online now
post #13 of 54 (permalink) Old 03-31-2019, 11:52 PM Thread Starter
I'm ready to sell the bike over how difficult it is to pull the carbs on this thing! If I get it back in and it still leaks....I might just pay someone to fix it.
Even the aligned boot leaked, but I'll try once more.
post #14 of 54 (permalink) Old 04-06-2019, 04:59 PM Thread Starter
Ok, I resolved the vacuum leak and synchronized the carbs. I adjusted the mixture screws for fastest idle (3.5 turns). When I ease on the throttle, it goes fine from idle to 4k, then drops a bit before struggling on up to redline.
Idle throttle response is snappy though.
https://photos.app.goo.gl/gjHQGttAK35q1e8c6
post #15 of 54 (permalink) Old 04-08-2019, 01:26 PM
Goats belly with mufflers removed able earshave? Probably should rejet.
Sent from my A502DL using Tapatalk
post #16 of 54 (permalink) Old 04-08-2019, 02:21 PM Thread Starter
No mufflers, straight pipes out of GB. I rejetted mains to 138, and added a shim.
post #17 of 54 (permalink) Old 04-08-2019, 02:31 PM
Might have to up the secondary jets too.
post #18 of 54 (permalink) Old 04-08-2019, 06:14 PM
Was going to say ... Maybe add shims on the needles. Couldn't hear the audio but watched the tach.
post #19 of 54 (permalink) Old 04-09-2019, 12:21 AM Thread Starter
It starts popping above 5k. I was still adding throttle as the RPM remained relatively constant. I didn't slow down on the throttle until about 7k, so as not to overrev it.
More shims? I figured the shims I have were causing the problems.
post #20 of 54 (permalink) Old 04-09-2019, 09:15 AM
If it's still behaving as it was in the first video, it seemed lean there. But since there's no audio in the second video, you may be right and it's running rich now that the carb boots are right.
The needles are tapered and pass through the main jets, so the higher they are lifted, the more fuel flows through the main jets. Adding shims lifts the needle higher, so more fuel.
Edit: Here's an annoying video with decent graphics describing the action.
