1996 VN750 Carb Removal---HELP - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 02-14-2019, 05:36 PM Thread Starter
Greetings, I got everything disconnected from the carbs. The boots are disconnected at the carbs. I cannot get the carbs out. I have tried to get the boots disconnected from the heads to no avail Is there any tricks to getting the boots out of there??? Thanks, Lew
lew441$ is offline
post #2 of 5 (permalink) Old 02-14-2019, 06:22 PM
Location: southern, western, middle Tennessee backwoods
The carb boots go on in a precise way, therefore it's wise to disconnect the left side front cylinder boot from the carb but leave the left front boot connected tight to the cylinder.
Get the rear right carb boot reconnected to the carb and tighten the clamp sufficiently.
Then disconnect the right side rear cylinder boot from the cylinder but leave the boot connected tight to the carb.
This way the carbs and boots will be lined up correctly when you put the carbs back on.
The boots are likely stuck and need some severe wiggling.
Careful you don't puncture or tear the boots with a screwdriver or some such tool.
Once the front carb is loose from the boot and the rear carb is loose from the cylinder, the carb set should twist out to the right side.
"I need yo clothes, yo boots and yo motocycle."- Uncle Bob
roadpouring is offline
post #3 of 5 (permalink) Old 02-15-2019, 07:22 AM Thread Starter
Thanks for the suggestions. I will try it today!!!
lew441$ is offline
post #4 of 5 (permalink) Old 02-15-2019, 11:08 AM
ubertalldude's Avatar
A little lubricant helps if you have some WD-40, silicone, white lithium, etc. It's somewhat of a twist & pull & cuss & sweat motion...
I've pulled 'em like 3 times, it's never an easy task.
ubertalldude is online now
post #5 of 5 (permalink) Old 02-23-2019, 12:27 PM
since people are talking about it and i never noticed before, i took a pic of the marks on the cylinder and the boot to show the reference marks for lining the boots up correctly. I didn't, and had to take the carb/boots back off the chase a vacuum leak.
1995 VN750
Ear Shave Mod
2-Wire Mod
Blue Wire Mod
RLU Bypass
SH847 R/R
Degoat
V&H Pipes
TheJabberWoggy is offline
