Backfiring - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 2 (permalink) Old 07-16-2018, 09:43 PM Thread Starter
Backfiring
Hello all. I’m getting into riding again (as I did years ago before I had kids) now the kids ride and I am now also. Also new to the group.
Getting to the point: I have a 94 VN750. The pipes were changed when I bought it although it backfires when letting off the throttle. I’ve adjusted the fuel/air screws and got it somewhat better. The right pipe doesn’t backfire at all now, but I can’t get the right adjustment for the other pipe.
Any suggestions would help.
Thank you in advance
Allen
Ahol025 is offline
post #2 of 2 (permalink) Old 08-24-2018, 12:54 PM
JETHRO's Avatar
could be the exhaust header pipe gasket not sealing properly
Vn 750 A2 1986 rebuilt engine, crank shaft, half casing,shell bearings,con rods,rear cylinder head,oil pump,water pump ,(had ceased bearing rusted up),tie bar upgrade,clutch basket drilled,front cylinder cam chains,toc springs,stator,shaved, rectifier,agm battery,solenoid ,starter motor (used) re-spray ongoing.
JETHRO is offline
