Stumped - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 6Likes
  • 1 Post By TonyO
  • 3 Post By bullwinkle
  • 1 Post By bullwinkle
  • 1 Post By JETHRO
post #1 of 10 (permalink) Old 07-05-2018, 07:20 PM Thread Starter
Addicted to Projects
bullwinkle's Avatar
Stumped
I've been away for a few years. Had a slip on ice going to work and back surgery/recovery. I'm trying to get my 85 vn700 back up and running after sitting. I've done all the routine stuff and some of the real fun stuff. Found out stater wasn't doing its thing so engine pulled and stater replaced.
But I'm still unable to ride her. In the last month I've pulled the carbs more times than I can count. The bike will idol beautifully but as I turn the throttle it bogs down about 4000 rpm. If I gently nurse the throttle I've gotten it up to around 6000 rpm. I can't ride gently nursing the throttle. I have inline fuel filters that I can see have fuel running through them but it's almost like the bike is running out of fuel.
I'm just stumped.
Any ideas from all you gurus?
Charlie
VN700 project bike 98% completed!!
68 Bushwhacker this winters project (in the works)
86 Honda GL1200i (winter project #2)
82 kz440 daily rider for now!
A few clowns short of a circus now aren't we?
bullwinkle is offline
post #2 of 10 (permalink) Old 07-06-2018, 12:01 PM
NewB to Vulcans
TonyO's Avatar
I added an inch of fuel hose to make tank removal easier. Then my bike had the same issues, would run fine at small throttle openings . Turns out the hose was kinked and restricting flow to one cylinder. Took away the extra inch and its just fine. Maybe your addition of the fuel filters is restricting flow?
OleDirtyDoc likes this.
'99 Vulcan "Victoria"
TonyO is offline
post #3 of 10 (permalink) Old 07-06-2018, 12:30 PM
Mine did not like in line filters either
post #4 of 10 (permalink) Old 07-06-2018, 01:25 PM
Yup, some have had problems using fuel filters, others say their's are working fine.
Make sure all the lines are at least running level to downward, none running uphill. With no filters, upward sloping hoses won't flow well.
Carb vents routed correctly? Problem would show up while moving only.
post #5 of 10 (permalink) Old 07-06-2018, 04:55 PM
Most dramatic fix for my bike was the tw200 petcock mod. Just rode way better when I did that. It's been a while and I could be dreaming but I sold that bike knowing it was working perfect.
post #6 of 10 (permalink) Old 07-06-2018, 05:38 PM Thread Starter
bullwinkle's Avatar
I guess I'll get some more new fuel line and give that a try. Thanks all.
Charlie
post #7 of 10 (permalink) Old 07-07-2018, 02:28 AM Thread Starter
bullwinkle's Avatar
Removing the inline fuel filters was the ticket. I never thought that would be the case because I simply replaced the old and put new ones on. I was able to get out and put about 30 miles on the bike, the first time in several years. Thanks again.
Charlie
post #8 of 10 (permalink) Old 07-10-2018, 11:07 AM
Those fuel filters build up a clear varnish-like coating over time. Particularly on long idle bikes. Same with petcock. Hot storage locations (outside?) profuce similar conditions.
BillinAustin is offline
post #9 of 10 (permalink) Old 07-11-2018, 02:08 AM Thread Starter
bullwinkle's Avatar
Well I didn't have any issues with the other inline fuel filters. They had the goldish colored granular looking filter. The brand new ones I replaced them with were a plastic with a plastic membrane as the substrate. They were positioned identical, very close to straight up and down. The fuel lines were dropping from the petcock through the filters into the carbs. The vulc would still bog down as the rpms went up around 4000. If I nursed it carefully I could work it up to around 6500, but it took some time. It wasn't going to make it for even a quick ride around the block.
After I took the inline filters off, she ran like a dream. It revved up great. I've finally been able to get back into the wind.
I can't explain how or why but without the inline filters it runs great.
roadpouring likes this.
Charlie
post #10 of 10 (permalink) Old 07-11-2018, 09:05 AM
JETHRO's Avatar
I have noticed that the plastic fuel filters are 6mm dia but you need 8mm dia to run these bikes same as fuel lines.
Vn 750 A2 1986 rebuilt engine, crank shaft, half casing,shell bearings,con rods,rear cylinder head,oil pump,water pump ,(had ceased bearing rusted up),tie bar upgrade,clutch basket drilled,front cylinder cam chains,toc springs,stator,shaved, rectifier,agm battery,solenoid ,starter motor (used) re-spray ongoing.
JETHRO is offline
