Do i need a re-jet - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 16 (permalink) Old 03-23-2009, 03:38 PM Thread Starter
Do i need a re-jet
ive got the vn700 1985/A1. UK import. the pipes dont look origional, ive replaced the filters
with small k and n's. removed all the origional filters. i think this is called the earshave. Havnt de-goated. YET
This is the first time ive been out on the bike and the problem is. it seems to hunt, like its
needing more fuel when cruising around the 60mph 70kmh mark. But When i crank the throttle open
great stuff, flys along... Seems to be around the 1/4 throttle...
I cant see the mixture screws on the carbs. I dont think its got them.
Ive taken carbs of to clean. Just the same.
Do i need to rejet?
Do i need to have a larger jet for the rear cylinder ie: 140 / 142? front
DO i need the small jets replaced to.
Ive looked on this forums and seems that some say you dont need to re-jet.
Little bit puzzled whether i should or not.
I cant get seafoam in the UK...
Any help be appreciated
My clutch is slippin badly to but thats another day
scotiaredd is offline
post #2 of 16 (permalink) Old 03-23-2009, 03:48 PM
The Professor
lance328's Avatar
Do i need to rejet?
Where do you live? Elevation?
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #3 of 16 (permalink) Old 03-23-2009, 03:57 PM Thread Starter
Auld Blighty Thats UK. I might drill the jets, anyone no size drill bit i need
to take them to 40. Thats if i need to re-jet, that is...
post #4 of 16 (permalink) Old 03-23-2009, 04:02 PM
The Professor
lance328's Avatar
You should be ok with #40 pilot jets #140 main jets 2 shims under the needles and 2 3/4 turns on the air/fuel screws. The screws are beside the vacuum port. You may have to remove the plug.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #5 of 16 (permalink) Old 03-23-2009, 04:06 PM
On His Lady Vulcan
wkrizan's Avatar
GOOD GAWD DONT DO THAT!!!
Yes you'll need to rejet, once you change the air flow you need to also chage the fuel flow. The standard jet sizes that seem to work for most is"
40 idle jets x2
140 main jets x2
#2 radio shack washers x4 (two under each needle)
Do those simple things and you'll love the new ride. But for gawds sake don't drill the jets, jets are supper cheap and even the slightest error in drilling will give you problems galor.
Peace
Pictures of the "Ladies"
wkrizan is offline
post #6 of 16 (permalink) Old 03-23-2009, 04:07 PM Thread Starter
nice1 i will try this next. ive done mods on other bikes like this but never really needed to shim n rejet.
the plugs look nice and tanned. thats why ive been reluctant to disturb the carbs...
post #7 of 16 (permalink) Old 03-23-2009, 04:12 PM
On His Lady Vulcan
wkrizan's Avatar
You'll get a good burn on the plugs even tho youre running lean, now ask yourself this question, do I want to run lean and save a few pennies in gass or run optimum and HAUL ASS?....LOL
Peace
wkrizan is offline
post #8 of 16 (permalink) Old 03-23-2009, 04:13 PM
The Professor
lance328's Avatar
Try turning your air/fuel screws out to 3 3/4 turns first. Below is a link that shows the screws.
https://www.vn750.com/forum/showthread.php?t=10094
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #9 of 16 (permalink) Old 03-23-2009, 04:15 PM Thread Starter
run optimum and HAUL ASS, Damn rite
post #10 of 16 (permalink) Old 03-23-2009, 04:18 PM Thread Starter
i had the carbs of and looked everywere for screws to turn but couldnt see any, lol...
Does the VN700 carbs have these. Sounds like a daft question, but you gotta ask, you guys no more than i do
