Choke Question - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 17 (permalink) Old 06-07-2018, 01:33 AM Thread Starter
MileHighVulcan's Avatar
Choke Question
Took apart my carbs due to it being over floated and got it all put back and everything seem to be fine. I took off the boots to the air box and put in k&n pods. I would be able to start my bike on full choke but I notice when it warm up before it would go to 4k rpm but now it only goes to 2k rpms, I'm guessing maybe it's due to not having enough pressure to hold the wire in place.
First question: Do riding with choke hurt the bike?
Second question: I would be able to ride the bike but when coming to a stop or slow down the bike would die (sometime it would stay on only with the choke on) most of the time it would die.(engine cut off)
Please help and much THANKS from the mile high city.
MileHighVulcan is offline
post #2 of 17 (permalink) Old 06-07-2018, 02:32 AM
Birga's Avatar
Sounds like your running lean, these bikes run lean anyway and switching to K&N's just adds more air. Check the color of your plugs to confirm it's running lean then turn your fuel screws out to 2 1/2 to 2 3/4 on both carbs to see if it fixes it.
As for running with the choke, i don't see why it would hurt it. The choke is an enrichment circuit adding gas to the carbs so it shouldn't hurt anything.
Hopefully one of the more experienced members will chime in.
Birga is offline
post #3 of 17 (permalink) Old 06-07-2018, 08:23 AM
Running with the choke won't "hurt" the bike, but it's an indication something's wrong....which should be fixed.
As suggested check your plugs, turn out your air screws AND reset your idle speed.
When you say you took off the boots to the airbox and put on pods, did you remove the system, or is that all you did?
post #4 of 17 (permalink) Old 06-07-2018, 12:10 PM
Yep, you are way lean. You can open the mix or you can put in larger pilot jets.
post #5 of 17 (permalink) Old 06-07-2018, 12:25 PM Thread Starter
That's all I did everything else is still in place. Should I remove everything else ?
post #6 of 17 (permalink) Old 06-07-2018, 12:29 PM Thread Starter
Sounds good, thank you
post #7 of 17 (permalink) Old 06-07-2018, 05:43 PM
Well I have not done what we call an "earshave" here, so not sure what exactly needs to be done, but I do know the air lines running to the reed valves suck air from the filter system, so now yours is not filtered. Ditto for the crankcase vent.
Perhaps someone more familiar with the installation of pod filters can chime in....
post #8 of 17 (permalink) Old 06-07-2018, 06:19 PM
Need to block off the reed boxes.
Need a filter on the crankcase vent hose.
Removing the air box frees up a lot of space, makes carb service easier. The airbox is just riding along now.
Are the carb vents still running into one ear? Ears still in place? Vents need to be in calm, still air.
post #9 of 17 (permalink) Old 06-07-2018, 09:27 PM Thread Starter
So, to get to the fuel switch screw I would have to drill both of the plate out to get to the screw ?
post #10 of 17 (permalink) Old 06-07-2018, 09:37 PM
yes the mixture screw lives behind that plug.. its soft, be careful drilling it, really just need a hole in it so that you can stick something in and pry it out
michiganteddybear is offline
