Question about my choke - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 05-26-2018, 07:43 PM Thread Starter
Freebird's Avatar
My choke was working not good but was working, I put 2 capfuls of seafoam in new tank of gas and sprayed some wd40 on misc parts and not the choke when pulled on goes right back to the start position?
Freebird is offline
post #2 of 5 (permalink) Old 05-26-2018, 08:10 PM
sounds like you freed up a stuck cable.. it should stay on, however, I do not know off hand if there is a tension adjustment for the choke lever. someone else will chime in here I am sure
post #3 of 5 (permalink) Old 05-26-2018, 11:46 PM
WilliamTech3's Avatar
Question
.....I had that problem many years ago, tho cannot remember how I resolved it.
Question: Does the throttle need to be twisted a little to allow Choke operation ?
WiliamTech3
Originally WilliamTech
Since May 2011
86 VN750 13,700 mi -Stock -Purchased 2008 w/8800mi
Jardine Fwd Controls, Custom Fenders w/Rails
Splines Lubed - 11/4/2012 - MF AGM Battery, Dampers went out @ 13+K !
...have a Vulcan good day !
WilliamTech3 is offline
post #4 of 5 (permalink) Old 05-27-2018, 12:03 PM
WiliamTech3
No the throttle does not need to be turned for the choke to work,as it is an enrichener.it sprays a little extra gas into the carb
post #5 of 5 (permalink) Old 05-27-2018, 12:34 PM
If you're saying the choke lever won't hold a position it's likely due to you over lubimg the lever. Try cleaning it out with contact cleaner. There needs to be a certain amount of friction to hold it in position.
