Bad Ma Kawi Lives up to her name - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 03-18-2009, 11:31 PM Thread Starter
Angry Bad Ma Kawi Lives up to her name
Howdy Vulcanites --
I dropped the scoot off a Mama Kawi's (Dealer) on Monday to rebuild the carbs. The estimate was $390 for parts and labor.
Bad Mama Kawi called me today to say that the exhaust has been radically modified. (I degoated & drilled baffles) So, the carbs will need to be jetted for a new estimate of $620. Without rejetting they said the bike will probably hesitate and not run right and they could not guarantee their work.
I said that rejetting is NOT necessary when the goat is removed or even when V&H pipies are installed. I told the service manager to please clean the carbs and leave them in stock condition. I will accept responsibility for any problems due to not rejetting.
I believe I'm right according to everything I've read on this forum. What do you folks think?
FlaRider is offline
post #2 of 12 (permalink) Old 03-19-2009, 05:31 AM
750Doug's Avatar
You're right. It's not needed at this point, don't let him take you there...
I also think you should grab your bike up before you lay out all that cash, and let us help you with the carbs, but that's just me.
Good luck with it and keep us posted. Some dealers are notorious for making things worse, or at least not any better.
I'm not familiar with any of your recent posts, do you feel pretty sure the carbs need to be removed and cleaned?
750Doug is offline
post #3 of 12 (permalink) Old 03-19-2009, 08:53 AM
flitecontrol's Avatar
Originally Posted by FlaRider View Post
Howdy Vulcanites --
Sure hope they don't do something that will make their hesitating prediction come true! If so, you'll have a better idea of the reliability of the dealership!
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #4 of 12 (permalink) Old 03-19-2009, 10:01 AM
The Professor
lance328's Avatar
Howdy Vulcanites --
You did the right thing but now they have an out if the don't rebuild them properly.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #5 of 12 (permalink) Old 03-19-2009, 10:41 AM
Kind of..... If any future problem is NOT related to jetting issues (ie: plugged jets or passages), then it'd still the dealer's fault to fix, IMO.
post #6 of 12 (permalink) Old 03-19-2009, 10:46 AM
The Professor
lance328's Avatar
You know the Stealership will say it is a jetting ussue!
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #7 of 12 (permalink) Old 03-19-2009, 02:26 PM Thread Starter
Hi Lance, 750Doug, FliteControl, Hyper --
Thank goodness I was right about not needing rejetting! This shop did good work on my previous rides back in the day when I did absolutely no wrenching. I had more $ and less time. So, I've got my fingers crossed hoping for the best.
I should have Mr. Spock back tomorrow. I'll let you all know how it goes.
Thanx everybody for your responses!
FlaRider is offline
post #8 of 12 (permalink) Old 03-19-2009, 02:29 PM
The Professor
lance328's Avatar
Call them and tell them you want ALL the replaced parts.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #9 of 12 (permalink) Old 03-19-2009, 02:46 PM Thread Starter
Good idea!
Thanx Lance.
FlaRider is offline
post #10 of 12 (permalink) Old 03-21-2009, 12:55 PM Thread Starter
Thumbs up Good Ma Kawi Redeems Herself!
Hey Lance and fellow Vulcanites --
I got lucky on the carbs! Mama Kawi (Dealer) did a great job rebuilding the carbs. The bike runs awesome--idles smoothly on BOTH cylinders, warms up quickly, throttle is very responsive, quick acceleration, and sounds great!! The old removed parts are in the attached photo.
Are pilot fuel screws mentioned by the Tech the same thing as the Air/Fuel mixture screws? Does this mean once I marble I won't need to turn out the Air/Fuel screws any more?
Here's part of the Tech's write-up:
"Carbs were dirty. Jet chambers filled with debris. Soaked carbs and blew thru all circuits. All passageways and circuits are clean. I had to turn the pilot fuel screws out to 3.75 to get a good C.O. reading. Bike starts easily and runs good when warmed up. This bike will need to warm up for a little bit before it runs it's best. With the stock pilot jets it is just too lean when cold. Carb sync is spot on. I drained the tank and filled it with fresh fuel and stabilizer.":
Now I need to resolve the other MAJOR problem: melted RR/Stator connector. See my recent post under electrical: "Voltage = 12.5."
FlaRider is offline
