Earshave question: What is a "coaster", how many needed for one bike - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 05-12-2018, 04:29 PM Thread Starter
Hi folks, considering doing an earshave, but don't know what this coaster thing is, and where they go...
NHVN750 is offline
post #2 of 7 (permalink) Old 05-12-2018, 06:49 PM
Coaster, is a metal plate to cover the hole where the reed box has been removed. You need two.
If you don't do coasters, the reed box itself can be capped or plugged.
Reed Box
The silver piece with the 5/8" hose clamped to it in this pic. This is the left side of the rear head, there's one just like it on the right side front head.
Coasters
post #3 of 7 (permalink) Old 05-12-2018, 07:11 PM
Jason Pittenger's Avatar
There are reed valves on each cylinder that open during deceleration (under vacuum).
This directs fresh air into the exhaust to burn off any unburned fuel.
This causes a popping noise under decel (assuming carb is properly tuned).
I posted a question about this step of the mod, and the consensus was it was only to remove the popping sound (or give a finger to the state of CA).
It has no effect on mpg or hp.
As far as location, there will be some vacuum hoses that attach to each cylinder.
Look for those.
Completed modifications:
Planned modifications:
Jason Pittenger is online now
post #4 of 7 (permalink) Old 05-16-2018, 10:34 PM Thread Starter
Thanks for the info! Are these coasters available to buy somewhere, or do you usually make your own?
NHVN750 is offline
post #5 of 7 (permalink) Old 05-17-2018, 09:31 AM
I made a set, but you can buy them. Look for 'vn750 reed plates' on ebay etc., price has gone up.
https://www.vn750.com/forum/31-engine...oasters-6.html
I hunted for some thicker aluminum, but the alum. stock they sell at hardware stores is thick enough since there's not much pressure from the port.
We had a member here making/selling them, but I haven't seen them in a while.
post #6 of 7 (permalink) Old 05-17-2018, 10:49 AM
I'm fairly interested in making some coasters that are ribbed. I think I saw one person post a picture of some here once, and thought they were a good match with the engine. If there's interest, I could make a small batch instead of just a 1-off pair.
Vulcan slang for newcomers
Service Manual Download
Thorn is offline
post #7 of 7 (permalink) Old 05-17-2018, 10:08 PM
Crowley was making them but he ain't been on the forum in a while
