02 VN750 not starting - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
  • 1 Post By Knifemaker
post #1 of 7 (permalink) Old 05-06-2018, 12:03 AM Thread Starter
So I have a vn750. I just cleaned the carbs there are no clogged jets. I checked there is fuel in the float bowls. The bike will start up fine if I spray some starter fluid but then die immediately. Any info would be appreciated!
goninja95 is offline
post #2 of 7 (permalink) Old 05-06-2018, 12:50 AM
Hey I’m new with all this but I am in a similar situation and I made some progress because someone here recommended me to check my choke so give that a shot if u haven’t, good luck !
Shah750vn is offline
post #3 of 7 (permalink) Old 05-14-2018, 03:22 PM
Jason Pittenger's Avatar
I would suspect you need more Choke.
But I'm relatively new here as well.
Try posting your question in the "Carbs and Fuel System" forum.
There are many very knowledgeable folks here that can help.
Completed modifications:
Planned modifications:
Jason Pittenger is offline
post #4 of 7 (permalink) Old 05-14-2018, 05:47 PM
goninja95, this section is for introducing yourself to the others here, which you really have not done.
I few sentences on your motorcycling experience and mechanical skills would be useful, as would where you live.
I am thus moving this thread to a more proper spot, and hope you find the time to give us a little information about yourself.
post #5 of 7 (permalink) Old 05-14-2018, 05:54 PM
As far as your problem. I've seen folks that claimed they "cleaned the carbs" but their pilot jet was still clogged. You should also check your choke...I assume you are using it when you try and start the bike?
You left out th bikes history. Was it running before?
Thorn likes this.
post #6 of 7 (permalink) Old 05-15-2018, 11:22 AM
It's not getting fuel so something is clogged.
post #7 of 7 (permalink) Old 05-15-2018, 12:11 PM
Vacuum line on the petcock missing???
