'85 VN700 fuel inlet brass upgrade, same size as 750? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 03-04-2018, 08:45 PM Thread Starter
I, in my infinite wisdom, cleaned and re-built my carbs entirely. Then I installed them into my bike and re-assembled everything. Got it running again and re-adjusted the settings. When I turned the bike off I came back to a puddle of gas between the cylinders and on the floor.
The plastic inlet on the right (rear cylinder) is cracked. So whatever fuel is left in the hose south of the petcock is draining out, and it leaks out while the bike is running also.
I've seen the threads with the brass replacements from Harley. But the site for those says they're for CVK 40, not CVK 32-38 or whatever the smaller size is. I know the carbs on the VN700 are Keihin CVK 34s. Does anyone know if these press-fit nipples have the same OD? They look about the same as the petcock nipples that feed them (0.388").
I'm thinking of buying some 1/8" NPT fittings and a tap, then holding them in with a little bit of blue loctite. I don't ever want to mess with this again.
Koloshiol is offline
post #2 of 5 (permalink) Old 03-05-2018, 10:12 AM
the 700 and 750 fuel nipples.. same beast.
some have put harley nipples on, but I am not an expert on that subject.
post #3 of 5 (permalink) Old 03-05-2018, 10:48 AM
Arctic Cat also uses the same carb as the VN750. I would say the CVK 40 should fit, 40 is the bore size, so it's not a huge difference.
Wolfie had posted here that the Harley inlet will fit. ... Post #4 - https://www.vn750.com/forum/22-carbs-...ng-broken.html
Link from Wolfie's post: https://cv-performance.com/harley-fuel-max-inlet-elbow
post #4 of 5 (permalink) Old 03-05-2018, 11:00 AM
I'd shop around, Wolfie's link below shows $17.95, but I found some for $5.95 and as high as $34.95 in an ebay listing that states that one fitting fits CVK 34, CVK 44, and CV 40 - 1976 to 2006.
Just a couple that I mentioned...
90 degree Fuel Inlet Fitting Press In
https://www.ebay.com/itm/HARLEY-DAVI...-/381595206429
post #5 of 5 (permalink) Old 03-05-2018, 11:04 AM
I clicked one more and found this one ay $8.95, a review there also said it fits a Kawi W650. https://www.ebay.com/p/Brass-Fuel-In...ter/1129927152
