RR Relocation - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 17 (permalink) Old 02-25-2009, 08:22 PM Thread Starter
RR Relocation
I just pulled the battery box off of my bike to sand clean and repaint. Which makes me consider relocating the rr like many people on this site suggest. From what I can tell its divided between preference of putting it front left or right rear. I read in one of the posts someone makes a bracket for the left front placement, what about the right rear? I am looking for cheap and simple, Im doing all of this work myself because I cant afford to sub any of it out and would like to hear some feedback of what I can do..
Thanks in advance guys
dastone07 is offline
post #2 of 17 (permalink) Old 02-25-2009, 08:46 PM
flitecontrol's Avatar
I made a simple bracket out of 1/8" aluminum and painted it black. You should be able to find a picture of the commercial bracket, or a link to one, on this forum. Mounted mine on frame below battery box. Per a recommendation on this forum, grounded it to - on battey.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #3 of 17 (permalink) Old 02-25-2009, 09:11 PM
fergy's Avatar
I have a link in my sig to a pictorial, with stuff you can get at home depot for cheap to do it with.
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #4 of 17 (permalink) Old 02-26-2009, 07:52 AM
darrelc5's Avatar
Of the two most common relocation methods, Fergy's is by far the best due to length of wires and final connector orientation. Spray paint everything black before final assembly and use thin rubber tubing or heatshrink tubing on the u-clamp to protect the frame's finish. Note that it's not necessary to electrically ground the case of the R/R. Also, it's a good idea to pack the connector with dielectric grease before you plug it back in.
Darrel
'03 Vulcan 750 (90k miles)
-Corbin Seat
-V-Force Windshield
-LeatherLyke Touring Bags
-Chrome Luggage Rack
-Headlight Modulator
-Brakelight Flasher
-MF Battery
-Heads-Up Voltage Monitor
-Replaced Stator (9,000 and 16,000 mi.)
-Oil-cooled Stator Mod (photos)
-Replaced and Relocated R/R
-Greased rear splines
-Fused Stator (photos)
-Metzeler ME880 Marathon 170/80-15 (Rear), 110/90-19 (Front)
-TOC MCCTs installed
-Headlight Relays
SOLD - 2013
darrelc5 is offline
post #5 of 17 (permalink) Old 03-09-2009, 02:29 AM
Jace Bror's Avatar
Great Write up there fergy. Looked at a lot. helped me out today with my spline. and i figured since i had everything apart to reloc the rr. I didn't do the drill out. I was able to get one bolt out and the other the head of the bolt came right off. now is where the fun began.
Now mind you i have never had elec problems with this bike. i was doing this a preventive maintenance. I was going to do the dielectric like you said. when i went to remove the connector pins, the plastic tab that is there to help keep the connector in broke. My bike is a 2000 not that old, but apparently enough. so i didn't remove the connector after that. cuz i don't need this thing coming apart in the future, at least until i can figure what to do.
so my ? is what to do? do i need to buy a new wiring harness and have to worry bout that thing being bad somewhere else? should i just remove it clean it. dialectic it and use silicone to hold it in place? help
Sold 750 (9-09)
Mustand Seat (6-09)
Balanced Carbs (4-09)
Adjusted Mix Screws (4-09)
R/R Relocated (3-09)
Splines Lubed (3-09)
Painted flat blak (3-09)
Kuri grips (8-08)
Kuri Longhorn pegs (8-08)
Iridium Plugs (8-08)
Highway bar/ engine guard(FS)
Facebook ID Eli Gaffke
Jace Bror is offline
post #6 of 17 (permalink) Old 03-09-2009, 02:39 AM
i definitely wouldn't silicone it in place. someone else would probably be able to better say but it shouldnt be too big a job to swap out the connector for it, assuming you can find the same connector. worst case, or temporary case, zip tie it in!
drguitarum2005 is offline
post #7 of 17 (permalink) Old 03-09-2009, 03:12 AM
Jace Bror's Avatar
yeah i could get the section with that connector. i know i can get a complete wiring harness that runs the whole bike. and that seems like a big pain. i figured the silicone would just go around the connector like bead, not fill it with silicone. I know i want to remove it at some point.
Sold 750 (9-09)
Mustand Seat (6-09)
Kuri grips (8-08)
post #8 of 17 (permalink) Old 03-10-2009, 12:01 AM
Simple Solutions
seebeeare's Avatar
I like the zip tie idea it can always be removed and as far as a connector a bike salvage yard may be the key to finding that, good luck with this indever but i wouldnt replace the whole thing for one connector thats a lot of work...
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
How To Test the Stator
seebeeare is offline
post #9 of 17 (permalink) Old 03-10-2009, 04:57 AM
I need to set up my desktop later today. Once I do, I have a catolouge saved on it that has all kinds of electrical connectors...to include both male and female six pin connectors the same style as our R/R... so it would be just a matter of making a harness about 6 to 8 inches longer and plugging it into the old harness on one end and into the R/R on the other end. I did this back in November with great results.
post #10 of 17 (permalink) Old 03-10-2009, 09:08 AM
Jace Bror's Avatar
ok the harness extension makes but, how does the new harness end plug into the old harness end since it is missing the tab?
Sold 750 (9-09)
Mustand Seat (6-09)
Kuri grips (8-08)
