flat battery after heavy rain - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 4Likes
post #1 of 11 (permalink) Old 10-20-2017, 08:11 AM Thread Starter
JETHRO's Avatar
Hi guys , Had a flat battery twice now after heavy rain, The second time had motorcycle cover over it but still did it.? In between runs and charges fine, left it with 12.9v, Checked today after storm reads 0, So now charging up battery, Why is this happening ? Anyone advise, Thanks Jethro.
Vn 750 A2 1986 rebuilt engine, crank shaft, half casing,shell bearings,con rods,rear cylinder head,oil pump,water pump ,(had ceased bearing rusted up),tie bar upgrade,clutch basket drilled,front cylinder cam chains,toc springs,stator,shaved, rectifier,agm battery,solenoid ,starter motor (used) re-spray ongoing.
JETHRO is offline
post #2 of 11 (permalink) Old 10-20-2017, 10:27 AM
you've got a bare wire somewhere
OleDirtyDoc is online now
post #3 of 11 (permalink) Old 10-20-2017, 11:51 AM
eltiti21's Avatar
check the wire harness you may have something wrong with it, and will make short when gets wet, check light, handle bar connectors and switches as well.
eltiti21 is offline
post #4 of 11 (permalink) Old 10-20-2017, 12:01 PM
eltiti21's Avatar
check also the electrical accessories cables that are loss on the right panel, and there is also another pair on front by the headlight, if they get wet they may consume power and drain the battery.
eltiti21 is offline
post #5 of 11 (permalink) Old 10-21-2017, 02:18 AM Thread Starter
JETHRO's Avatar
ok thanks for input ,gonna be a bitch to find problem.
JETHRO is offline
post #6 of 11 (permalink) Old 10-21-2017, 10:14 AM
check the headlight bucket
post #7 of 11 (permalink) Old 10-22-2017, 12:16 AM Thread Starter
JETHRO's Avatar
Ok will do, just thinking maybe a good idea to fit an on/off switch just in front of the positive terminal to isolate battery when not in use
JETHRO is offline
post #8 of 11 (permalink) Old 10-22-2017, 01:09 AM Thread Starter
JETHRO's Avatar
I do need to look at the ignition switch as I never had it apart and looking through forums it seems this is a part that can be troublesome.
JETHRO is offline
post #9 of 11 (permalink) Old 10-25-2017, 04:33 AM Thread Starter
JETHRO's Avatar
Update on battery drain, Well got round to putting battery back on after re-charge and when connecting negative terminal the fan started up, So disconnected the radiator fan thermo switch and no drain, So I think this is the problem . I looked on Kawasaki UK for replacement and they want 90 US dollars + postage for one, But on ebay I can get one made by caltric from USA for half that including postage, So my order is placed hopefully this does the fix.
OleDirtyDoc and ubertalldude like this.
JETHRO is offline
post #10 of 11 (permalink) Old 10-25-2017, 11:36 AM
ubertalldude's Avatar
Glad you found the source of draw, let us know how it goes and if it fixes it!
ubertalldude is online now
