Restore the 86 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 10-02-2017, 11:42 AM Thread Starter
Matthew Wellington's Avatar
Restore the 86
So it's been awhile since I have been in here, I'm doing all that I can to restore my bike. So I'm doing away with the stator mod and such. I'm replacing the rotor/stator plate and pick ups. As I was riding from the shop where I broke down at, half way home I lost power to one cylinder had had to limp 100 miles home on the freeway. The shop told me that they had to sauder one of my pick up wires in place because it broke on them while fixing my stator. Sure enough that was the cylinder that died on my ( rear) so I'm going to replace both pick ups and coils, the stator plate, seals ( I leak oil no matter what I do) and alternator rotor. I pray this works or I will be out of options and have to sell the bike. I love this bike but I can't have it break down on me every week. And I don't have time to troubleshoot every issue I see
Don't worry!!, It's just a bump in the road.
Matthew Wellington is offline
post #2 of 11 (permalink) Old 11-12-2017, 06:50 PM Thread Starter
Alright, I replaced the stator and cover, new seals and I timed the rotor and balencer. When I turn the choke on it dies, but at idle is sounds fine. When I give it gas the RPMs go up but won't come back down until I adjust the idle screw. A little back story was I had one of my pick ups die and ran on one cylinder for a while. I replaced the pick ups and now I'm running into all types of issues. Any ideas? I checked the compression and I'm at 120 on both cylinders
post #3 of 11 (permalink) Old 11-12-2017, 06:51 PM Thread Starter
It's like I'm running in one cylinder at idle then 2 when I give it gas. I'm at a complete loss
post #4 of 11 (permalink) Old 11-13-2017, 05:48 AM
Location: Southern Maryland, Waldorf/LaPlata/Indian Head area
Jets could be too big if it won't idle down. Did you change jet size?
1985 700 Vulcan / Purchased 13,636 miles currently 19,126/Fork Seals & Dust Covers/Ignition Switch/AGM Battery/Hell Fire Windshield/River Roads Saddle Bags/Coil Relay Mod/2Wire Mod/RLU Bypass/Head Light Switch/Voltage monitor Green light/Mosfit R&R/Tuxedo Mod/Stator/Point Gap .020/ Dampers/Rear Signal & Brake Light LED'S/Rebuilt Shutoff Valve/Final Drive Gear Oil/Brake Shoes/Spline & Hub Lube/11 inch Progressive Shocks/De Goated/Engine Guard/Rejetted For K/N Pods/TOC mcct's
Sparkys73150 is offline
post #5 of 11 (permalink) Old 11-13-2017, 08:09 AM
at idle,does one of your exhaust pipes stay cold?if one cylinder isn't firing could have a sticky or dirty float needle,causing it to flood at low rpms
OleDirtyDoc is online now
post #6 of 11 (permalink) Old 12-10-2017, 11:56 PM Thread Starter
Sorry that Im just getting back to you. Iím looking into the carbs now. I have them pulled and on my bench but havenít had the time to tear them down yet. Thank you for the replies!
post #7 of 11 (permalink) Old 12-11-2017, 12:34 PM
Could also be a clogged pilot jet. It gets no gas at idle and just above, then fires up when the main jet kicks in. Mine ran that way with one pilot jet plugged.
post #8 of 11 (permalink) Old 01-11-2018, 08:43 AM Thread Starter
It just wonít start.. Iím moving to San Diego here in the next month. I will bring the bike with me but I donít see me owning this bike much longer due to the reliability I just need to do a full motor rebuild.
post #9 of 11 (permalink) Old 01-12-2018, 12:48 PM Thread Starter
Thank you Spockster for all the help bud. You guys have been awesome. I just donít have the funding to upkeep the bike.
post #10 of 11 (permalink) Old 01-12-2018, 05:16 PM
Rarely do you need a full motor rebuild.
Did you accidentally swap the pickup locations? That could lead to some real running issues.
If you're dropping a cyl its either fuel or electrical somewhere.
