For LED turnsignals - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 02-13-2009, 07:42 PM Thread Starter
gusdaman89's Avatar
For LED turnsignals
I just came across this site and instead of spending 15 bucks on an electronic unit, there is a 2 dollar NAPA one you can buy. Check it out.
http://www.bugmanweb.com/gsxr/flasher.html
There are also some other cool things on this site that could be helpful to Vulcan owners.
Enjoy
GUS
Project Black and Gray
2004 VN750
Arlen Ness Mirrors
Custom covered seat
Custom taillights
Fenders undercoated
gusdaman89 is offline
post #2 of 4 (permalink) Old 02-14-2009, 04:19 PM
The Professor
lance328's Avatar
That flasher will not allow hazard function and will not allow you to use LED and Incandescent together, an electronic 3-prong flasher will.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #3 of 4 (permalink) Old 02-15-2009, 08:53 AM
I couldnt get the electronic or any other to work right on my bike ( I worked at ADVANCE AP, so I tried them all)
What I did was this...took two old turn sockets with bulbs...wired them in with the rear LEDs...as if to have 2 sets of rears. I used enough wire to run them under the seat near the battery box. I wrapped each one (bulb and socket) in black tape. Then side by side, I wrapped the two together and made a small "pack" out of them. Its very small, hides well and works perfect.
All the functions work as they should.
Custom Cow is offline
post #4 of 4 (permalink) Old 02-18-2009, 09:48 PM
cglennon's Avatar
This model TMI EL98N worked on a 2006 VN750 with LED turn signals both front and rear. Pick it up on Ebay. Plug-n-play, with no problems so far.
Chris Glennon - Portland, OR
cglennon is online now
