Stator replacement - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 85 (permalink) Old 09-15-2017, 03:09 AM Thread Starter
Stator replacement
So I'm sure there's 40 other posts on this but I like to have a current place for me to get what I need so I just got a 1998 Vulcan 750 and the battery just won't stay charged and I check the 3 hello wires all of which I was getting number from my bolt meter when I had black to negative and touching the red to the yellow wires while the bike is off so does this mean the stator is grounding out there for bad?
If so what is a list of parts I will need and how hard is it to change I've seen people do the "tuxedo mod" with cover still on the bike is that ok to do I'm not looking to have a 15hr project but don't wanna spend 900$ so have a shop fix this I need help here folks anything
Jacob Peterson is offline
post #2 of 85 (permalink) Old 09-15-2017, 07:54 AM
did you check your r&r?what about the connector to the r&r?sometimes they corrode or burn out.would you mind giving us an introduction in the newbie section? some have had luck with the tuxedo mod on the bike but I have also seen it go bad,as yo can get metal shavings in the motor.it's not that hard to pull the motor to do it right.
OleDirtyDoc is online now
post #3 of 85 (permalink) Old 09-15-2017, 08:00 AM
read the sticky in the electrical section on testing the charging system
post #4 of 85 (permalink) Old 09-16-2017, 04:43 AM
Matthew Wellington's Avatar
I have gone through about 3-4 stators in a week due to misc errors in my bike. The tux mod did not do well for me but it is s good idea to look at nonetheless. There are quite a few posts open for testing the stator and R/R.
Don't worry!!, It's just a bump in the road.
Matthew Wellington is offline
post #5 of 85 (permalink) Old 09-18-2017, 12:35 AM Thread Starter
So I've been running a few tests and my stator is not grounding out but is only putting out
1100rpm 20vac
3000rpm 47vac
5000rpm 69vac
So would this mean I have a good stator my battery with the bike off is at 12.5v and at idle is only reading 12v at 3000rpm it reads 12.45v then after I shut the bike down and check the battery it reads 12.5v
It never gets to the 13-15v every one talks about
post #6 of 85 (permalink) Old 09-18-2017, 08:22 AM
ubertalldude's Avatar
Sounds like your stator is in good enough shape, but your charging is not good enough. This would likely mean that your R/R is dead or very close to dying. You would do well to replace your R/R or upgrade to a MOSFET/Series style while you're at it.
ubertalldude is online now
post #7 of 85 (permalink) Old 09-18-2017, 08:31 AM
check the plug on the r&r.could also have a bad battery
post #8 of 85 (permalink) Old 09-18-2017, 12:11 PM Thread Starter
I did check the plug for the regulator got it pretty cleaned up could someone attach a link for the best regulator to buy I plan to buy this battery unless someone know of a different one
https://m.ebay.com/itm/YB14L-A2-High...%257Ciid%253A3
post #9 of 85 (permalink) Old 09-18-2017, 08:00 PM
did you test the regular?
post #10 of 85 (permalink) Old 09-18-2017, 09:02 PM Thread Starter
No I can't seem to find a guide to testing the regulator
