She died - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 2Likes
post #1 of 29 (permalink) Old 09-01-2017, 05:36 AM Thread Starter
She died
Hi,
She died today.
My bike started beautifully today, way better than many other times...
I rode off, but before leaving the street she started to hold back.... When I stopped and she tried to run stationary (is that correct english?) the engine started to run irregular. like... tada.. bam ... tada ... bam. Just like she missed a blow each cycle.
After a minute she just died... and now when I turn the key, nothing reacts, no ligths, no startengine, nothing...
Will put the battery on the charger today, to see if it charges then... If this works, it's likely the battery is empty and is not being charged underway... That would suck. The dynamo is just over a year old.
Any other ideas what could be happening here? I know something, but am not too technical.
Cheers,
Tuckson is offline
post #2 of 29 (permalink) Old 09-01-2017, 07:48 AM
Originally Posted by Tuckson View Post
Hi,
She died today.
Cheers,
Check if there is charging power 14,5 v at 4000rpm if not check the regulator rectifier (R/R) if that is not the problem chech the stator
Verzonden vanaf mijn iPhone met Tapatalk
mvdijck is offline
post #3 of 29 (permalink) Old 09-01-2017, 08:37 AM
Have you cleaned the ignition switch? The puck under the key? You would be surprised at the havoc that fkin thing throws at you.
post #4 of 29 (permalink) Old 09-01-2017, 09:00 AM Thread Starter
Sorry, english is not my native language... what do you mean with the 'puck under the key'?
Tuckson is offline
post #5 of 29 (permalink) Old 09-01-2017, 09:19 AM
the ignition switch is 2 parts, the lock cylinder (where key goes), and the switch itself (looks like a hockey puck with wires).
many people think the lock cylinder is the switch. that is incorrect. cleaning the lock cylinder does not clean the switch itself.
you can remove the switch fairly easily, without a lot of other stuff needing to be removed first.
michiganteddybear is offline
post #6 of 29 (permalink) Old 09-01-2017, 09:31 AM Thread Starter
thnx for the clarification. will have a look at this as well.
Cheers
Tuckson is offline
post #7 of 29 (permalink) Old 09-01-2017, 12:03 PM
cglennon's Avatar
How old is the battery and what type of battery is it?
Your problem could just be a dead battery. These bikes will not run without a battery. I got 7 years out of my Yuasa AGM before it died and left me stranded (thank you AAA). The bike started up just fine on that day with no indication that the battery was failing (e.g., weak starter noise). The volt meter indicated proper charging conditions throughout the ride. When the battery finally died (and the engine along with it), there was barely enough power to faintly light up dash.
Chris Glennon - Portland, OR
cglennon is offline
post #8 of 29 (permalink) Old 09-01-2017, 02:43 PM
There are ball bearings and little springs in the ignition switch so be careful not to lose them!
post #9 of 29 (permalink) Old 09-09-2017, 06:16 AM Thread Starter
Well, had it checked by a repairguy. An honest one, that is ;-)
The good news is, it was just the fuse. She's running again.
The very very bad news is that the fuse that burned was a 15A fuse. There should be a 10A fuse in it.
His words:" the inner of this engine is litterally taped together and I don't know where to start to check things out. Everything seems even rotten".
It's not that he really does not know of course, it's more that he cannot give any guarantee to find the culprit quickly and he advises not to spend any extra money on this bike since he does not know where it ends.
So, that was a very short lovestory of me and my vn750.
I think the only option left is the see if someone is willing to pay a few bucks for a projectbike.
I'm sad, because I loved the way it rides, but do not have the money at the moment to get another one.
Tuckson is offline
post #10 of 29 (permalink) Old 09-09-2017, 11:33 AM
why not just buy a wire harness on ebay?not a hard replacement. they're going from about $40 to $100
