Turn Signal Out - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 5Likes
post #1 of 22 (permalink) Old 08-15-2017, 06:10 PM Thread Starter
Turn Signal Out
Rear turn signals were both working, I noticed that the right signal has stopped working. Are there some steps I can take to look for the problem? Checked verses but didn't see anything on this. Thanks!
boogiepop35 is offline
post #2 of 22 (permalink) Old 08-15-2017, 08:45 PM
does the front come on but not blink?check the bulb
Thorn likes this.
post #3 of 22 (permalink) Old 08-16-2017, 10:51 AM Thread Starter
The front signals both work, the rear signals had been working but only the left one is currently working. Yes I will check the bulb that's easy should've thought of it. Is there a good guide somewhere on how to remove rear signals?
post #4 of 22 (permalink) Old 08-16-2017, 10:55 AM
should be screws on the lenses. but it's weird the front still blinks with the rear not working
post #5 of 22 (permalink) Old 08-16-2017, 09:00 PM
I think it will just blink quicker if the rear one burns out.
OleDirtyDoc likes this.
post #6 of 22 (permalink) Old 08-16-2017, 09:21 PM
yes Sharky,your right.I haven't been on my Vulcan in way too long.these damn Honda's I've been on just don't blink at all
post #7 of 22 (permalink) Old 08-17-2017, 10:05 AM Thread Starter
Hey so I played with it last night. The funny thing is that it blinks fine when I put on the hazards. But when I use the right signal alone it will not work. The front signals are both fine, and the rear left is fine. Just the rear right won't work on its own. Does this make any sense?
I have a Voyager trike kit on it with its own set of coffin signals on each of the trike tire fenders. And they both work fine, but I am not sure it will pass inspection without the bike's own rear signals working - any thoughts?
Unscrewed the turn signal lens easily, and there was an additional screw on the inside of the housing I unscrewed too, but I could not figure out how to get the bulb out. I wanted to swap bulbs with the left rear to see if that had any impact. Not sure how to get that bulb out though. Pulled it pretty hard but didn't wanna break it in case that's not the right way to do it.
post #8 of 22 (permalink) Old 08-17-2017, 10:23 AM
push in a little and turn,then pull out.should turn counter clockwise, if I remember
Paulywog and Thorn like this.
post #9 of 22 (permalink) Old 08-17-2017, 10:24 AM
also,look at the bulb.there is a little metal filament inside the glass. it should be connected at both sides with no breaks in it
post #10 of 22 (permalink) Old 08-17-2017, 10:29 AM
ok,with the turn signals from the trike kit,it'll blink fine.probably a blown bulb.
