Head light twitches - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 08-15-2017, 04:02 PM Thread Starter
Head light twitches
Hello all,
My head light has the tendecy of flickering if the motor does not start up on the first spin. it also cuts out sporadically while I am driving, most of the time a restart fixes the problem but not always. I know these bike have a headlight reserve could this be causing me the problem?
Thank you for the help in advance
Andre
dre82s is offline
post #2 of 4 (permalink) Old 08-16-2017, 04:49 AM
If the flickering is related to starting the bike (i.e. a half-start causes flickering, or restarting fixes the flicker) then I'd guess your headlight relay found in the junction box is going bad. In stock configuration the relay is triggered by incoming voltage from the stator, then should stay on solid until the ignition is turned to 'off'. Once the "blue wire mod" has been performed, the relay is bypassed and the headlight will come on when the ignition is turned to 'on' and will stay on until ignition is turned to 'off'.
The blue wire mod can be done in a non-destructive way so you can ride around for a while to see if that fixes the problem before you decide if you want to splice wires.
LED headlights can flicker due to the RLU, but that shouldn't happen with the stock headlamp.
Vulcan slang for newcomers
Service Manual Download
Thorn is offline
post #3 of 4 (permalink) Old 08-18-2017, 10:08 AM Thread Starter
I have installed HID light, I forgot to mention it. I will check on the relay to see what I can come up with. Thank you for the reply
dre82s is offline
post #4 of 4 (permalink) Old 08-18-2017, 07:37 PM
If your new HID bulb draws less amperage than the stock bulb, then your RLU might be freaking out after all. Look up the RLU bypass mod.
Thorn is offline
