At the RLU module connector, I jumped the blue wire to the blue/yellow wire, start up the bike and no headlight at all. Unless I manage to get the Hi-Lo switch in between hi & lo, then I'll get a high beam only. If i connect the RLU back up in the stock configuration the headlight works but with a flicker at low RPM. Its a nuisance more than anything because I know I should be able to get LED headlight to play nice with the bike. Am I missing something with this mod? My Vulcan is a 1995, could there be a wiring difference from the sticky's configuration and my bike?
One other thing that I have noticed about my bike is that the hi & low beams seem to be wired backwards. If the button is pushed to Hi the low beam configuration is lit. However, if I push the button to Lo then extra LEDs turn on in what would appear to e the beam configuration.
Otherwise I love the LED headlight. Not only does it illuminate the road better, it just looks better.
The pic I promised you will be up in a few hours, been extremely busy last couple of days. I suspect you jumped the wrong wires. Can you post a pic of the wires you jumped?
Your beam selector switch is backwards when the RLU is in place? Has it been that way since you got it?
Double check to make sure the blue wire is jumped to the blue/yellow wire, not the blue/orange wire. It's possible those two wires got switched at the molex connector ...
I bought the bike from my brother who bought it used for his now ex-wife. From day one I rode with the selector on Hi because Lo seemed to be brighter, and focused higher up (when facing my garage door). I plan to do some wire checking this weekend because it clearly lights the second LED element with I switch from hi to lo. Then turns off the extra LEDs when I switch to hi.
Iceshot, thank you for the pictures. I jumped those exact wires, just like you. Heck I even tried 2 gauges of wire and a paperclip to make sure it wasn't something simple. If I remove the connector jump the solid blue to the blue/yellow the start the bike I have no head light no matter what position on the selector. Plug it back into the RLU and we have light selectable on hi-lo. I've been an electronics tech for a very long time and the mod matches the schematics and should work as described. I got that .00001% that doesn't work lol.
I'll post any new information I find. For now it works, just flickers a little at low RPM.
Got to love chasing the wires! Doing the blue-wire mod would be useful for doing diagnostics without having to start the bike to energize the headlight. Good luck!
Finally got to do some troubleshooting. The center connector (red/yel) of the H4 socket is the Lo beam, the left connector (blk/yel) is ground, and the right connector (red/blk) is Hi beam. All connectors are wired correctly for the headlight. However, the switch when flipped to Hi I have voltage on the center contact. When the switch is flipped Lo I have on the right contact. Which leads me to the Hi/Lo switch being wired backwards.
I've included a picture of my switch. I have a yellow wire that is not accounted for in the service manual diagram (from the ignition maybe?). If I understand the wiring of the Hi/Lo switch it would appear that my red/black & red/yellow wires are switched. Which would account for the Lo beam on the Hi setting and vise versa. Does anyone know if i'm correct?
Well, I opened mine up and it's wired just like yours, yellow wire and everything.
Can't find the yellow wire on any schematics either. Wonder if that wire even connects up to anything on the harness at the molex connector...
I wondered about that, and checked the schematics for the early models, but there's no mention of that wire anywhere. Also, how would the dimmer switch affect the turn signals? Seems like Kaw might have manufactured one switch to use on several models, some of which utilized the yellow wire (alternate RLU system?), some of which didn't. I'm feeling too lazy right now to investigate. :|
Final Update on the RLU blues. I've finally eliminated the RLU. I did the blue wire mod at the JB. However instead of jumping blue to blue/yellow, I had to jump blue to blue/orange. Not totally sure why mine is different. I tried to fix the head light Hi/Lo problem but so far no go on that.
Glad to hear your making headway on figuring it out. Post up some pics of the led headlamp installed! :grin2:
Related Threads
Kawasaki VN750 Forum
411.9K posts
42.2K members
Since 2000
