LED License Plate Light - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 01-24-2009, 01:13 PM Thread Starter
cglennon's Avatar
I found a small panel LED car dome light replacement on eBay for $5 and thought it would be a good fit for the VN750 license plate R5W bulb. I know that switching this particular bulb to LED is a bit overkill, since it saves only 5 watts of power, but every watt counts. Anyway, I needed a quick and easy winter project.
The LED panel light came with several connectors for various car dome and door sockets, but none fit the license plate socket, so I made a custom connector using the existing bulb. First, I wrapped the R5W glass bulb in a paper towel and broke the glass using a set of pliers and de-soldiered the existing wires. Next I soldiered in the new LED wires, careful to match the correct polarity. I made a c-loop using a piece of wire cut from a coat hanger to server as an installation handle. I just inserted the open end into the empty bulb base. Finally, I filled the base with silicone adhesive to hold it all in place (see attached picture). The back of the LED panel came with an adhesive strip backing, which I used to mount the panel to the VN750 bulb reflector. Fit perfectly.
The result is a brighter, bluish-white light at a fraction of a watt and the whole mode took only a few minutes (my kind of mod).
Chris Glennon - Portland, OR
cglennon is offline
post #2 of 14 (permalink) Old 01-24-2009, 01:28 PM
letitflight's Avatar
it looks good man !
PEACE!!!
2005 Vulcan 750
letitflight is offline
post #3 of 14 (permalink) Old 01-24-2009, 04:00 PM
cm4cm5's Avatar
job well done.
Jeff Brooks
Owensboro KY
'94 Vulcan 750
cm4cm5 is offline
post #4 of 14 (permalink) Old 01-24-2009, 04:19 PM
Great job!
The loop you put in the socket is just what Clear Alternatives shoulda done with their tail/brakelight LED board.
post #5 of 14 (permalink) Old 01-24-2009, 04:42 PM
should last longer than a regular bulb, i'll bet it will last forever.
Mastertech is offline
post #6 of 14 (permalink) Old 01-24-2009, 07:22 PM
The Professor
lance328's Avatar
I'll have to get one now!
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #7 of 14 (permalink) Old 01-24-2009, 08:01 PM
I have ordered a few of these and am still waiting for it to arrive - been 2 weeks. My plan was to replace all lights Indicators and Tail. Just a note of caution to anyone who wants to use these - please ensure they have resistors in the circuits if not you will soon blow the leds. What I expect from my project is to have something brighter and better than the ClearAlternatives solution but at a fraction of the cost. If i am successfull - expect a DIY here for the benefit of all.
Not a Virgin but has a Halo
RogerGA is offline
post #8 of 14 (permalink) Old 01-24-2009, 08:38 PM
The Professor
lance328's Avatar
Make sure you change out your flasher unit.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #9 of 14 (permalink) Old 01-24-2009, 08:59 PM
Yes - Have that in the To-Do list
RogerGA is offline
post #10 of 14 (permalink) Old 01-25-2009, 07:43 PM Thread Starter
cglennon's Avatar
I have upgraded the turn signal, brake and running lights using Radiantz 1.85" dual intensity clusters. Found them on eBay for $3/piece (Retail for $24). I used three clusters for the brake/running light, one cluster in each turn signal and two clusters in a second brake light (picked up a trailer lense housing from an RV supply store for $4) that I mounted it on the sissy bar. Wired all to clusted the existing bulb casings, just like the license plate LED panel in the picture, making installation plug-n-play.
I will say that the Radiantz clusters are much brighter than the LED panel I used for the license plate. I'm not sure which LEDs you purchased, but hope that they brighter than the LED panel I bought for the license plate.
cglennon is offline
