Need help diagnosis:power loss/tach inop/restart solves issue??? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 01-19-2009, 10:20 PM Thread Starter
wicker san antonio
Twice now I have lost power like loss of fuel. Pulled over switched to aux.tank to no avail. In neutral will rev up fine but engage clutch and lugs down....then I noticed the tach was inop. Turned the bike off and restared, tach came back and full power returned. This has happend twice in the last 300 miles. Bike is 2002 and has almost 11000 miles. I have put the last 6000 on it since May 08.......Anyone had this experience?
Thanks. WWicker/ San Antonio
wwicker is offline
post #2 of 6 (permalink) Old 01-19-2009, 11:02 PM
start at the battery... make sure all the conections are tight... that used to happen in my car...
bigrepp61 is offline
post #3 of 6 (permalink) Old 01-19-2009, 11:58 PM
The Professor
lance328's Avatar
Along with checking the battery connections check the frame ground connection and the engine ground connection. The tach. gets it's signal from the front coil, check the coil wires and the wires around the frame neck. You could also have a pickup coil problem?
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #4 of 6 (permalink) Old 01-20-2009, 10:27 AM
^^^^ X2... wasnt thinking straight.... grounds too..
post #5 of 6 (permalink) Old 01-22-2009, 09:28 AM
Love My Baby
rubyrick's Avatar
One more thing: It may be the "phantom out of gas syndrome." This is usually caused by a blocked vent in the fuel tank cap. Try opening then closing the fuel tank cap (can't do while riding unless you have a spare key already in the cap). It's happened to me a few times in the past. Try doing a forum search on phantom out of gas syndrome to get more info.
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
LED license plate frame
X
rubyrick is offline
post #6 of 6 (permalink) Old 01-27-2009, 05:41 PM Thread Starter
wicker san antonio
Thanks for all the tips. Will check all elec. connections. Also did not think of the gas cap vacuum problem until you mentioned it...will try that next time however I think it is probably an electrical problem since the tach stops working when the problem occurs.
W.Wicker/San Antonio
wwicker is offline
