Beware Cheap Chinese voltmeters - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
  • 1 Post By kc2dgq
post #1 of 6 (permalink) Old 07-24-2017, 10:22 PM Thread Starter
NewB to Vulcans
TonyO's Avatar
As part of making an over discharge protection circuit I decided to check the calibration of the el cheapo flea bay voltmeter I installed. Damm thing can be as much as 0.8 Volts off!!!!
Name:	2017-07-24 19.05.10.jpg
ID:	39705   Click image for larger version
Name:	2017-07-24 20.44.01.jpg
'99 Vulcan "Victoria"
TonyO is offline
post #2 of 6 (permalink) Old 07-25-2017, 07:07 PM
I think that most of those digital voltage displays are not as accurate as one would like them to be.
The number displayed is not a critical as you think.......let me explain.
Knowing what your charging system is doing is more important than the actual numbers. at idle, you would not expect much charging taking place, but at the higher RPM, you want to see a higher voltage(system is charging).
Sitting at a stoplight with brake lights on and possibly the radiator fan running...you expect to see a lower voltage...this is normal.
I installed a simple LED on my dash that tells me what the system is doing...not the actual voltage....that keeps it simple, green is acceptable voltage, flashing green is charging, and red means battery voltage is low.
HERE is the link to my thread for my LED indicator install.
One1 likes this.
post #3 of 6 (permalink) Old 07-25-2017, 07:50 PM
Yes. Good voltmeters will usually say how accurate they are. (+/- 0.1 volts e.g.) Good ones also usually have an adjustment to alter them if they are wrong.
But yes, numbers are relative, if you check one against another that you trust, you will then know what to add or subtract when looking at the one that's wrong.
post #4 of 6 (permalink) Old 07-25-2017, 10:06 PM
When I looked at those, they had +/-1v in the specs, some weren't waterproof. Still better than not having one.
There's really a wide selection of meters now, just looking on Ebay.
post #5 of 6 (permalink) Old 07-31-2017, 06:24 PM
HardRock's Avatar
X2
I replaced my gas gauge with a voltmeter, now that part of my dash gives me info I can use rather then telling me that I still have a full tank with 75 miles on the trip meter.
HardRock is offline
post #6 of 6 (permalink) Old 07-31-2017, 07:47 PM
Originally Posted by HardRock View Post
X2
Look at the miles on that puppy!
Meter looks factory that way.
