7" LED Projector Headlamp Conversion with pics! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 8Likes
post #1 of 51 (permalink) Old 07-01-2017, 10:13 PM Thread Starter
Cool 7" LED Projector Headlamp Conversion "How To" with pics!
Just finished upgrading the old and tired looking Halogen headlamp to a projector LED headlamp. A VAST improvement in light output!
Low Beam
High Beam
LED Conversion (Speedo / Tach / Indicator Lights)
Unfortunately, this was not a simple headlight swap. To make it work, it required a completely different headlamp assembly (bucket, trim & mounting rings). I used the headlight assembly off a Kawasaki 1976-1979 KZ750-B (see pic above). This headlight bucket kit is crossed referenced and used on several other 70-early 80's Kawasaki motorcycles. The kit I used is a aftermarket reproduction, the OEM part number it copies is 23005-1015-21.
Guy on Ebay z1-parts-inc sells them brand new shipped for $66 (all metal chrome, no plastic)! Other Ebay vendors sell them as well, averaging between $60-70 Link here...
https://www.ebay.com/itm/Head-Light-...H/164044802216
(Note) You will reuse the mounting rubber inserts and bolts /nuts from your factory bucket.
LED headlamp is a Sunpie 7" LED Headlight (see link below). Can be found on Ebay and Amazon for roughly $60. Got a open box one off Ebay for $38 shipped, so shop around.
https://www.amazon.com/Headlight-Dav.../dp/B018LXCS0C
To prevent flickering and provide a steady stream of current to the headlamp, you will need to bypass the reverse lighting unit. Thorn has a how-to with pics here...
https://www.vn750.com/forum/19-elect...ting-unit.html
Here's a "How To" video on using the Kawasaki KZ750-B (1976-1979) headlight assembly with the LED projector headlight...
VulcanMKE "how to" video based on this mod (Thanks Man!)
So for less than a $100, very worthwhile mod!
1993 Vulcan 750 "T'Pol"
Cobra Full Exhaust (Single Sided)
M/F AGM Battery
NGK Iridium Plugs
Shinko 777 Tires
Sunpie 7" LED Projector Headlight / KZ750-B 76-79 Bucket & Trim
Full LED Bulb Conversion
Mustang Wide Regal Seat
Aftermarket Grips & Mirror's
Full Chrome Tach / Speedometer
Mobil 1 75-90 Synthetic Gear Oil
Rotella T6 / Bosch 3323 Filter
Iceshot is offline
post #2 of 51 (permalink) Old 07-01-2017, 10:39 PM
I like it
post #3 of 51 (permalink) Old 07-02-2017, 09:04 AM
NewB to Vulcans
TonyO's Avatar
Looks Good. Can you do a nightime pic? How much brighter does the headlight appear to be?
'99 Vulcan "Victoria"
TonyO is offline
post #4 of 51 (permalink) Old 07-02-2017, 02:14 PM Thread Starter
I will work on getting some nighttime pics. In the meantime, guy did a side by side comparison riding at night with the stock halogen unit vs the Sunpie Daymaker LED headlamp. As I said, vast improvement! Check it out here...
M/F AGM Battery
NGK Iridium Plugs
Shinko 777 Tires
Iceshot is offline
post #5 of 51 (permalink) Old 07-07-2017, 12:51 PM
80w LED
The light you reference is a 40W unit but there is also an 80W unit for HD motorcycles. I keep trying to find specs on the 80W LED Daymaker. Just I want to know if 80W is max at hi-beam or low-beam, etc. Here is the link:
https://www.amazon.com/Daymaker-Head.../dp/B01KWVS7NS
I believe a stock bulb draws 40W on low and 60 on high. Does anyone know of the 80W version is just too much of a draw on the charging system?
bassace is offline
post #6 of 51 (permalink) Old 07-07-2017, 01:03 PM
NewB to Vulcans
TonyO's Avatar
I use an "off road" H4 bulb in my ride, Wagner Lighting BP1210H4 Halogen, it runs 80W low beam and 100W high beam. I have had no problems in the 10 months its been installed.
OleDirtyDoc likes this.
TonyO is offline
post #7 of 51 (permalink) Old 07-07-2017, 01:32 PM
I'm gonna have to find one for the Goldwing. already have 100w driving lights but can't see **** after dark so I need lotsa light
post #8 of 51 (permalink) Old 07-07-2017, 01:47 PM
NewB to Vulcans
TonyO's Avatar
Be a little cautious about "80W" I have a bunch of LED's that are "10W" in the advertising but only draw 5W of electricity, bright little suckers though.
8,000 Lumens? That's fricking bright, almost dangerous. makes you wonder if those are Chinese Lumens or real ones.
TonyO is offline
post #9 of 51 (permalink) Old 07-07-2017, 01:51 PM
the 80w that was mentioned was H4
post #10 of 51 (permalink) Old 07-07-2017, 02:00 PM
NewB to Vulcans
TonyO's Avatar
We were also discussing an 80W LED "Daymaker" from a Chinese source via Amazon. The Chinese are known for very inflationary lumen estimates in their advertising. They use the same chip LED's (from Cree) as most everyone else but somehow they claim WAAAY more light in Lumens than the chip itself can produce. That's why I asked for side by side light comparisons in my first response.
TonyO is offline
