charging problem - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 06-30-2017, 10:25 PM Thread Starter
vullcan22's Avatar
Question charging problem
So went for a ride today and turned my volt meter on and it's showing 12.4 -12.6 volts at 3500-5000 rpm any other time it's 14.00v or 14.5v.I turned around went back home put battery on charger and it dont seem to be taking a charge.could that be the reason why I'm seeing the low voltage?
ok the 3 wires coming from the stator are they all the same I fixed the bullet connectors and might of gotten them mixed up when i put them back together is that a problem?
no loss of power the bike running great beside's the engine noise
nothing in life comes easy
vullcan22 is offline
post #2 of 4 (permalink) Old 06-30-2017, 10:47 PM
the three wires don't matter.check your connectors at the rectifier
post #3 of 4 (permalink) Old 07-01-2017, 07:29 PM Thread Starter
vullcan22's Avatar
you are right again found a burnt pin on the r/r plug thank you for the help now I gotta find a r/r and time's are hard right now dont have 100$ to spend on one if any1 you know has one I'm interested
post #4 of 4 (permalink) Old 07-01-2017, 10:28 PM
you're welcome. check out eBay
