First Mod - Voltmeter & Accessory Charger - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 06-29-2017, 01:01 PM Thread Starter
Smile First Mod - Voltmeter & Accessory Charger
Just finished my first mod a couple nights ago. I decided to add a 5v accessory charger and voltmeter to my bike. Originally I wanted to put a combination voltmeter/ammeter that I bought of flea bay but I couldn’t find a cup or bracket to put it above the dash. Plus, wiring up the ammeter wasn’t very clear.
I used a relay to trigger power to both the voltmeter and the accessory charger. I took pictures but it’s hard to see the relay tucked in behind the front coil pack. I picked up the 10A spare wire & ground in the headlamp bucket and “t” off the blue wire for the left running light. Unfortunately I didn’t take a pic of the headlamp bucket wiring.
I can’t thank the forums and contributors enough for giving me all the information I needed to complete this mod and other issues. You all have helped me replace a leaky radiator drain bolt (way cheaper than the OEM part). Change the rear gear oil. Spline lube is next in my future.
ID:	38673   Click image for larger version
ID:	38681   Click image for larger version
ID:	38689   Click image for larger version
ID:	38697   Click image for larger version
bassace is offline
post #2 of 9 (permalink) Old 06-29-2017, 02:22 PM
Mod
Birdhunter02's Avatar
Nice. I took a car analog volt meter and mounted it on the dash as well. I wouldn't charge anything with the bike off. Might be to much of a drain.
2003 1600 Classic
Sold
900 Seat Mod
Iradiun Plugs
V and H Cruzers
Windshield with Lowers
LED Tail Lights
Saddle bags
Chads Floor boards
Highway pegs
Birdhunter02 is offline
post #3 of 9 (permalink) Old 06-29-2017, 03:58 PM
ubertalldude's Avatar
seems like he has it relayed so it only comes on once the key is turned. Nicely done! I never though of using those neck covers to mount things. I wound up buying a dash plate to install mine. (pics in my signature if you're interested)
Earshave+Rejet (38/135) – NGK Iridiums – MCCT Conversion – Slipstreamer S03 Windshield – Custom Extended Backrest – Custom Highway Bars – MOSFET R/R – LED Underglow – Volt+USB In-DashTwo-Wire & Blue-Wire Mod – Satin Black Engine Paint – Dampers Parts - Jets: Main=99101-393(#132 stock)/Pilot=n424-22 Pilot(#38 stock)
ubertalldude is offline
post #4 of 9 (permalink) Old 06-30-2017, 01:04 PM
I was thinking about relocating the horns behind the neck covers but was wondering about the effect on the electrical components from all the heat from the cooling system back there (and also how muffled they might be, but that's a separate question). Any issues with your project?
LandyLou is offline
post #5 of 9 (permalink) Old 06-30-2017, 01:37 PM
The 5v stuff only charges in miiliamps, so it's not much draw at all. My friend got hit up for charging three smartphones and a vape pen in one afternoon while at a gathering, no problem, but he does have a new agm batt.
post #6 of 9 (permalink) Old 06-30-2017, 02:54 PM Thread Starter
Not yet, I've only had everything in place for about 5 days. I'll update in a month or so.
bassace is offline
post #7 of 9 (permalink) Old 06-30-2017, 05:35 PM
Ok, thanks man!
LandyLou is offline
post #8 of 9 (permalink) Old 06-30-2017, 07:24 PM
NewB to Vulcans
TonyO's Avatar
Er Um, some of the 5 V stuff charges at an amp, most of it will take >1.5A happily, USB wall chargers can go to 3A and the USB connector is rated at 5A.
I have car lighter chargers that do 2.1A out of three ports.
'99 Vulcan "Victoria"
TonyO is offline
post #9 of 9 (permalink) Old 06-30-2017, 07:50 PM
Ok. Checked all of mine, they're 500-650 ma, including the wall chargers. Even one 12v cordless landline charger is 500ma, I use those as battery tenders for the bikes.
My camera wall charger is 400ma.
No doubt there are exceptions, but the lower rate is the most common, I'd say.
